Autocad 2022 is Slow and my curser response delay
dhavamani.munusamy
dhavamani.munusamy
Am working autocad 2018 and 2022. autocad 2018 is nothing problem. but, when I work with 2022 my curser is struggle and response is slow.
Can you please anyone help. Thanks
0 Me gusta
Responder
Soluciones aceptadas (2)
592 Vistas
4 Respuestas
Respuestas (4)
vinodkl
Solución aceptada
Hi @dhavamani.munusamy
Type in the command "3DCONFIG" and check if its turned on. If its turned "off" then turn it "on" and see if that makes any difference. If this doesn't help then please post a screen recording of AutoCAD so that we can help you out :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
Have you installed the 2022.1 Update yet? Start ABOUT command to find out. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2022: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
0 Me gusta
dhavamani.munusamy
Thank you @vinodkl. I have try this option still not working.
0 Me gusta
dhavamani.munusamy
Hi Pendean. Thanks for your quick response. Now its working for me.
0 Me gusta
