AutoCAD 2022: How to ungroup multiple groups in one go?
JamaL9722060
JamaL9722060
I couldn’t figure out if there is a tool that can ungroup multiple groups in one go when selecting the entire drawing.
For example, in the screenshots below, selecting the entire drawing shows that there are 7 groups. How can I ungroup them in one go? The group manager shows no thing
The dwg file is attached
Jamal Numan
tramber
Don't forget to put the "include unamed" option on !
Remember also the CTRL+H shortcut to vary the PICKSTYLE variable value.
Kent1Cooper
@JamaL9722060 wrote:
AutoCAD 2022: How to ungroup multiple groups in one go? .... when selecting the entire drawing.
No selection is needed:
Command: UNGROUP
Select group or [Name]: ALL
Explode 3 groups? [Yes/No] <N>: Y
3 groups exploded.
Kent Cooper, AIA
tramber
it is true that doing in one go in the dialog box is not possible !
pendean
Community Legend
Community Legend
@JamaL9722060 Did you not ask the same question like a few weeks ago?
You can Toggle groups on/off with
CTRL+H
or
CTRL+SHIFT+A
Explore more here https://www.autodesk.com/shortcuts/autocad
JamaL9722060
Thank you guys for the help
It works fine with the solution provided by Kent1Cooper
Jamal Numan
Type a product name
