AutoCAD 2022 and Windows 11
jogle
jogle
Has anyone had issues with AutoCAD 2022 functionality while running Windows 11? I am not sure if Windows 11 is supported yet or not but my IT manager keeps installing it on new employee computers and they seem to be the only computers we have issues with after loading AutoCAD. I believe it has been limited to the 2022 version. The main issue seems to be custom noting and command .cuix files seem to be unloading randomly.
ennujozlagam
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Will-A...
https://forums.autodesk.com/t5/autocad-forum/windows-11/td-p/10608389
pendean
Community Legend
Community Legend
Have you installed the 2022.1.2 Update yet? It has some WIn11 fixes in it. ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
Some shaky PC setups also need GFXDX12 variable set to 0 (that's a zero) then restart R2022: reverting to DirectX11 fixes problems for some users too.
If all else fails, start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
TerryDotson
... command .cuix files seem to be unloading randomly.
I've seen that for many years (versions and even OSs), on partial CUIX files at least.  Keep in mind that AutoCAD won't remember more than a certain number of partial menus, the limit being 21 (from memory).  Here's a technical post on it (from a coding standpoint).
