AutoCAD 2021 Layout not working create view
LenKwaiKeong8457
Message 1 of 9
LenKwaiKeong8457
HI, I have a computer that use autocad 2021 does not work, how can I solve it?
Replies (8)
Message 2 of 9
imadHabash
I suggest to right click on Layout button up there on Ribbon contextual tab then try to check    Show tabs / Show panels  options . If it's not solved try to Reset AutoCAD to default settings .
Imad Habash
Message 3 of 9
LenKwaiKeong8457
I don't understand where you are referring to the following, do you have any pictures?
"right click on Layout button up there on Ribbon contextual tab then try to check    Show tabs / Show panels  options"
Reset AutoCAD , I've tried it, but it doesn't work.
Message 4 of 9
imadHabash
Imad Habash
Message 5 of 9
LenKwaiKeong8457
HI, Already checked, useless.
Message 6 of 9
imadHabash
Would you try to check if any updates needed ? >> Click <<
Imad Habash
Message 7 of 9
pendean
Community Legend
Community Legend
@LenKwaiKeong8457 Is R2021 a new installation?
Or just not current to the 2021.1.2 level as listed in your ABOUT command?
Or are you running a modified CUIx file that has those removed? Did you force a previous menu file from an LT setup for example?
Or in a workspace that has those elements removed? Those elements re not there specifically for you for some reason we have no access to, sorry. Dig a lot deeper into your CUIx file origins.
Good luck.
Message 8 of 9
LenKwaiKeong8457
Hi, I'm logged in as USER A and ran into this problem. I don't even know what he did. If I log in as USER B on the same PC, there is no such problem. I have updated to the new service pack but still the same. We have contacted the Malaysian distributor for assistance. But they also have no solution. Anyway, thanks for your help.
Message 9 of 9
pendean
Community Legend
Community Legend
You may just have to give the user all new log-in credentials. It happens sometimes.
