AutoCAD 2021 - Commands not working properly as before
morten.eriksenAPTEP
Community Visitor
morten.eriksenAPTEP
Community Visitor
Community Visitor
After installing Autocad 2021 I have issues with commands that worked perfectly on previous versions.
1. The (J) join-command is not working for me at all.
2. The (G) Group command has been changed so I need to do many more steps to make a group.
3. Normal (CO) copy-command I usually had set to "Multiple", but it is now stuck on single, even when I change it. I therefore have to use (COPYM) for the same functionality, which takes more time.
I use this commands a lot and would love some help to fix these issues.
NB! I run Windows 10 64-bit edition and AutoCAD 2021
0 Me gusta
Responder
904 Vistas
2 Respuestas
Respuestas (2)
imadHabash
1- Sorry ... What do you mean by " (J) join-command is not working " ?!! :cara_con_una_leve_sonrisa:
2- We wish to know how it's changed ( as you said) ?!! But you may need to check PICKSTYLE (System Variable) also it's good to know Commands for Working With Groups Here
3- For multiple copy you have to check the mOde option in copy command .
Command: COPY
Select objects: Specify opposite corner: 1 found
Select objects:
Current settings: Copy mode = Multiple
Specify base point or [Displacement/mOde] <Displacement>: O
Enter a copy mode option [Single/Multiple] <Multiple>:
Imad Habash
0 Me gusta
pendean
Community Legend
Community Legend
1. What does that mean? We can't see what you are doing. Works fine here as always.
2. Did you move from LT by chance to full AutoCAD? LT's quick little handy command is not found there. Or did you forget to install a custom LISP or something else that you had in older versions? Or is PICKSTYLE not set correctly?
3. Watch the commandline to reactivate multiple option: or use COPYMODE command for change it. You do have that turned on and taller than a single line, yes? And you look over there often, right?
0 Me gusta
