AutoCAD Forum
Autocad 2020/Windows10 Cannot create .VnavantH (.TTF )font style in command line
2 REPLIES 2
652 Views, 2 Replies
As title, after I installed cad 2020 on new PC use windows 10, I Cannot create .vnavantH font style in command prompt. But in text style window is available.
Anyone can help me. Please
Ps: I can still do it previously on autocad 2018 or on Windows 7. Why?
Many thanks!
2 REPLIES 2
pendean
What type of TTF font is it? There are two types, only one is supported in AutoCAD and there is nothing you can do about it sadly.
in reply to: pendean
Thanks for your help!
More information: I have tried on many PC and realized this error is only available on my PC 😞
The difference is my computer installed Windows 10 v1903 or higher (not updated from v1803), and the other PC are Windows 10 updated from v1803, even if I use cad 2016, it will not work. The conclusion is due to the new Windows 10, but I can't fix it.
For example:
1/
(command "-style" "STANDARD" ".VnAvantH" "" "0.75" "" "" "")
->result: "Specify font name or font filename (for SHX) <txt>: .VnavantH
Font file doesn't exist."
(I confirm that I have installed this font (TTF) in Windows)
2/
(command "-style" "ARIAL" "Arial" "" "0.75" "" "" "")
->result: " "ARIAL" is now the current text style."
AutoCAD Inside the Factory
