AutoCAD 2020 - "Invalid" when inserting block
There is a "standards" block that my company inserts into most projects at the start, which includes numerous layers, linetypes, blocks, etc. that we frequently use. I noticed that after making the switch to AutoCAD 2020, I get an "Invalid" message every time I go to insert our "standards" block. The block inserts just fine in AutoCAD 2018 and previous versions. I have tried opening the standards and saving them from AutoCAD 2020, but still get the Invalid message when trying to insert. I have this issue using either the classicinsert command or new insert command. I have all available updates installed, including 2020.1.1 that was released today (11/7/19).
I have not installed the "Block Hotfix" because I assume that this would have already been pushed through in one of the service pack updates.
My current work around is to insert the standards block in AutoCAD 2018, save and close the file, and then open it and continue to work in AutoCAD 2020. I have no issues inserting blocks that are embedded in the standards block in AutoCAD 2020, but cannot seem to insert the standards block itself. Obviously, this is frustrating, so I am looking for a little input on how I might be able to resolve this issue with inserting blocks in AutoCAD 2020.
Thanks in advance!
