AutoCAD 2020 - Leader by using group code, its not opening in AutoCAD 2013
deepankarsama
Observer Observer
deepankarsama
Observer
Observer
I have added basic Leader using its group code and its working in autocad2020 but when I tried to open it on autocad2013 it's not working.
[ The subject line of this post has been edited for clarity by @handjonathan Original: I have added Leader by using group code, its not opening in autocad 2013 but works in autocad 2020 why? ]
cadffm
Why it fails on 2013 but not in 2020, I don't know.
(you forgot to post the error message, and it is also often a good idea to post a small as possible sample file 😉 )
But okay:
But I guess it would also work in 2013 if you would define this Leader well!
I miss the DXF 3 code (the dimstyle name what the leader refers to) / before the 76 code
The 3 . dimstylename is not documented as optional information
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-396B2369-F89F-47D7-8223-8B7FB794F9F3
(yes I know, for usual it works, but it isn't documented as optional data)
Sebastian
deepankarsama
Observer
Observer
Thank you.
After adding the dimension style name its working 🎉
