AutoCAD 2020 - Layer names are missing from the layer property tab
jtruscott1971
Observer Observer
jtruscott1971
Observer
Observer
Good afternoon, I've got a series of drawings and dxf files that are showing no layer definitions in the Layer Properties tab.  The geometry is there and shows the correct layer name in the properties tab to the left.
Looking for advice as to how to retrieve the layer properties info.
Thanks.
[ The subject line of this post has been edited to include the product name and version by @handjonathan ]
pendean
Community Legend
Community Legend
So this all worked before today in your autocad2020 software? If yes, then restart your PC and try again.
If this is a problem in ALL files after the restart of the PC, including your own files from last week, then you probably need to reinstall AutoCAD2020 then ensure it is fully updated to 2020.1.5 level https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
TheCADnoob
have you tried to run AUDIT on the problem files?
CADnoob
jtruscott1971
Observer
Observer
Assuming I did it right, no issues were found.
jtruscott1971
Observer
Observer
It is only on certain files dating back to 2017. Also looks like they had some geometric constraints applied.
Rebooting did not solve the issue.
pendean
Community Legend
Community Legend
@jtruscott1971 I suspect you'll have to share one of more of these unique files then for others to dissect the issue.
paullimapa
Have you tried opening the file using RECOVER command?
Paul Li
IT Specialist
@The Office
