For the first time I'm working on existing dwg files that I only have in PDF format, so I use PDF Attach and then I overlay solid hatch on top of them, with various transparency settings.
I don't often use the transparency setting, so whenever I do any updates, it will be the last thing I notice is not working as it used before (e.g. when I had AutoCAD 2019 installed and used an older version of Adobe Acrobat Pro DC).
The result of all my plots (plotting to A1 sheets) using the Adobe Acrobat Pro DC PDF printer, is a sheet that plots the attached PDF file only, and totally ignores the solid hatching that has transparency that I added on top of the PDF.
I can't figure out whether the issue is with AutoCAD 2020 or with the version of Adobe Acrobat Pro DC (v2019.012.20040) or not, however, using this printer even yield discoloured PDF files from within AutoCAD 2020 (and not with any other software I print on using Adobe Acrobat Pro DC). Printing using Adobe Acrobat Pro DC is also VERY SLOW for some reason of late, and I cannot pinpoint where the issue is, because this never used to be like this.
When I change the printer to AutoCAD's built-in PDF printer, the drawings print just fine, with the solid hatch displaying and with transparency. The built-in PDF printer also prints much faster than Adobe Acrobat Pro DC, which is all a new situation from what I used to have in previous versions of AutoCAD while using Adobe Acrobat PDF printer.
I'm about to download and apply the latest AutoCAD 2020 update and see if this has no effect on the issues I'm having on Adobe Acrobat Pro DC.
And the reason I often use Adobe Acrobat Pro DC is that, on some drawings, there is a noticeable difference in PDF quality between AutoCAD's built PDF printer vs. Adobe Acrobat Pro DC's printer. And I prefer Adobe's printer. However, it is not working as it used.
