AutoCAD 2020 - Cursor not showing distance [NOT DYNAMIC INPUT]
CADMENOC1
Message 1 of 32
CADMENOC1
How do I get the cursor to show the distance when I move my mouse away from the starting point? I've searched the help and forums and cannot find any information regarding my problem without the Dynamic Input being the culprit. I DO NOT mean Dynamic Input. I have included 2 pics, one without dynamic input on and this is what I am after. The second shows dynamic input on and this is not what I want. I had to open version 2017 to get Autocad to do this. I am currently running 2020.
Thank you for any information you can give regarding this problem.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (31)
Message 2 of 32
Patchy
DYNMODE, try 0,1,2,or 3  pick the one you like.
Message 3 of 32
CADMENOC1
Hi, Thanks for the response. Unfortunately those don't work. They all either turn Dynamic input on (1-3) or off (0). I only want to run when it's off and still see the distance, as in picture (1) That I posted. I believe this is not a dynamic input issue. I believe it has to be something else.
Message 5 of 32
CADMENOC1
Hi, thanks for the suggestion but nothing in the link solved my problem. It seems like that's the same problem I'm having but I don't have the time to reset Autocad to it's defaults at this time. If it does work, I wouldn't know how to distinguish between which system variable is turned off or on on the default state compared to how I'm running. I did try all the other suggestions in the link and nothing worked.
Any other suggestions would be greatly appreciated.
Message 6 of 32
Kent1Cooper
So how did you make the image that shows what you want?
Kent Cooper, AIA
Message 7 of 32
CADMENOC1
I opened Autocad 2017 and just drew a line then took a screenshot using the Windows snipping tool. (I'm having the problem with 2020). The 2017 looked like the default version when I opened it. Is there is a way to compare all system variables associated with this problem as a list? maybe a list of all ACAD system variables and their current settings.
Message 8 of 32
Patchy
Use the command SETVAR then type in a ?
on each version and compare line by line ☺
Message 9 of 32
CADMENOC1
Thanks, I ran it and copied each page to Excel and saw that there are 975 sys var lines to go through on 2020. I now am going to run the same command on 2017 and somehow will have to go through almost 1900 lines to compare which ones may or may not be causing this. I wonder if there is another way to do this?
Message 10 of 32
CADMENOC1
Another thing I did notice on the 2017 version is ORTHO (F8) has to be on in order to see the dist/angle. If it's off, it doesn't work.
Message 11 of 32
CADMENOC1
Well, I went through all 1930 +/- system variables. There were about 100 that were different and none were what I was looking for. I'm at a total loss on what to do. I tried all of them that were different and they didn't change the problem I'm having.
If anyone has any ideas, I'd love to hear them...
Message 12 of 32
mike
Community Visitor
Community Visitor
Not sure that you have resolved this, try using the F12 key to turn off and on.
Message 13 of 32
Kent1Cooper
Late to the party, but since the topic has been revived:
To get the display as desired in the original image, without Dynamic Input, you need to have Polar Tracking on [F10 key toggles it].  In the DSETTINGS dialog box:
The comment in Message 10 about it only working with Ortho on would be from having the "Track orthogonally only" button picked on the right.  But even without that, it only displays along Polar Angle Settings increments, so you may want to set that to a lower value than shown here.
Kent Cooper, AIA
Message 14 of 32
CADMENOC1
I wanted to give an update. We have upgraded to 2022 and that has solved the problem. All system variables were imported from the previous version to the new version and it has started working again. I was never able to solve this problem before the upgrade & import of old settings either.
Edit: as of 6/30/22 the problem has resurfaced. If anyone has had this problem and has been able to find a solution, please share. No changes to  the software or any system variables have been made. This just started on it's own.
Message 15 of 32
drewVGXUA
I had this problem and solved it by checking this box in Options:
"Display AutoTrack tooltip"
Message 16 of 32
usmanitayeba
Community Visitor
Community Visitor
Thank you for this, I've been struggling with the same problem on AutoCad 2022 as well, playing around with the settings on DSETTINGS < Dynamic Input allowed me to see the values live alongside the cursor.
(I ticked "Enable dimension input where possible")
Message 17 of 32
cmontoyaPC6FF
Community Visitor
Community Visitor
In Drafting Settings (DS) under Pointer Input, click on Settings.  Select Cartesian Format, Relative Coordinates, and Always - even when not in command.  Should show distance after these changes.
Message 18 of 32
rbaker
Community Visitor
Community Visitor
Message 19 of 32
blacyD955J
it is F11 for me
Message 20 of 32
cjmcad09
Hi, thanks for your reply but toggling object snap tracking on/off does not correct the problem.
