AutoCAD 2020 can't osnap to blocks or Xrefs in different viewports
Dxy00
Dxy00
I am using AutoCAD 2020 simplified-Chinese version and everything is set to default except 4 apps (AutoAlign, ReplaceBlocks, Drawing Purge and Change Block Base Point) I downloaded from Autodesk App Store.
After making two ViewPorts in model space I find that osnap doesn't work properly between ViewPorts.
For example, in model space when you use move (or copy) command only in ViewPorts 1, the osnap works fine to blocks and Xrefs in ViewPorts 1 . However when you want to Move (or copy) form ViewPorts 1 to ViewPorts 2, I find that I can't osnap to blocks or Xrefs in ViewPorts 2. (While using Ctrl+Shift+C and Ctrl+Shift+V between ViewPorts, the osnap works fine)
That is frustrating and I am pretty sure that function woks fine in AutoCAD 2014 and I have test it with same brand new dwg files.
Is it a known issue and will be fixed in future with hotfix or service pack?
0 Me gusta
Responder
Soluciones aceptadas (1)
521 Vistas
4 Respuestas
Respuestas (4)
Alfred.NESWADBA
Solución aceptada
Please make sure you are having the latest update installed (AutoCAD 2020.1)
Please start AutoCAD with parameter /safemode (as shown >>>here<<<) and try the same again.
If that does not help then please create a small sample drawing so we can try it on our systems.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
vinodkl
Have you checked if Ortho (F8) is turned on?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
Dxy00
After installing AutoCAD 2020.1 update, the problem is solved.
Thanks !
0 Me gusta
Dxy00
It's still not working either Orthomode is on or off.
After installing 2020.1 update,  it is fixed.
0 Me gusta
