apparently there is a gremlin in my autocad LT 2020 [with no lisps of course].
here's what i got when inspecting the command line as suggested:
Command: OFFSET
Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0
Specify offset distance or [Through/Erase/Layer] <144.0000>: 12
Select object to offset or [Exit/Undo] <Exit>:
Specify point on side to offset or [Exit/Multiple/Undo] <Exit>:
Select object to offset or [Exit/Undo] <Exit>: *Cancel*
Command: DIST
Specify first point:
Specify second point or [Multiple points]:
Distance = 40.0392, Angle in XY Plane = 357.5, Angle from XY Plane = 0.0
Delta X = 40.0000, Delta Y = -1.7717, Delta Z = 0.0000
Command: DIST
Distance = 15.0107, Angle in XY Plane = 87.8, Angle from XY Plane = 0.0
Delta X = 0.5675, Delta Y = 15.0000, Delta Z = 0.0000
**** System Variable Changed ****
1 of the monitored system variables has changed from the preferred value. Use SYSVARMONITOR command to view changes.
Command: SYSVARMONITOR
Command: SELECTIONPREVIEW
Enter new value for SELECTIONPREVIEW <0>: 3
**** No System Variable Changed ****
so i get the message that selection preview has changed [on its own cause no reason]. i change it back from 0 to [preferred, just as i had it set] 3. and i get a prompt that no, it wasn't changed?
WTH?
