AutoCAD 2019 Retain Changes to XREF layers
octavio2
octavio2
I notice (it seems) that the Retain Changes to Layers made iin the XRef command that was available in previous versions of AutoCAD in the Options dialog seems to be missing (or hidden) in the Options dialog of AutoCAD 2019 and AutoCAC Lite 2019.
The changes to the layers in the XREfs now are retained by default?  Or the command is still hidden there somewhere and has to be activated?
Please advise.
0 Me gusta
Responder
6.226 Vistas
12 Respuestas
Respuestas (12)
imadHabash
try VISRETAIN system variable from command line , and from OPTIONS dialog ( Open and Save tab ) you will find it there . >> Click >>
Edit : The option to Retain changes to Xref layers (VISRETAIN system variable) has moved from the Options dialog box (Open and Save tab) to the Layer Settings dialog box. also you have to check VISRETAINMODE (System Variable) that Controls the behavior of the VISRETAIN system variable when it's set to 1.
Imad Habash
No aplicable
Hi i see that in v2019 and in 2020 to..
Audodesk want too create the old Autocad v12 :cara_con_la_lengua_fuera: the user need the keyboard and a good memory.
With all the sysvar you have to deal with..
Why have you delete the option in the option tab ?   I need this one all the time when i  want to check my xref ..
Annoning..
0 Me gusta
RobDraw
Annoning..
It was moved to the layer manager which actually makes sense. It's just as easy to access. If that doesn't work for you, there are many ways to make accessing it easier. Complaining isn't one of them, BTW.
Rob
0 Me gusta
scmallory
I have 300 drawings that I need to apply this too.. If I do this once will it apply to all drawings or will I have to open all 300 drawings and change the settings of the VISRETAINMODE
0 Me gusta
pendean
Community Legend
Community Legend
VISRETAINMODE is a system wide variable: look it up in HELP. You should be able to change it only once.
HTH
0 Me gusta
BrauseFrufo
Sorry, it's a longer time ago for this problem, but I just start with acad2020 and I can't find that button, also not at the layer manager.
And why is it a system variable now? Are you sure? In former times it depends to the dwg, so it was possible to have dwgs with different option.
Cheers
0 Me gusta
RobDraw
If you read the posts correctly, there are two variables, one for the file and one system.
This is how you get to VISRETAIN settings:
Rob
BrauseFrufo
Thank you
There was no need for me to use this little wheel there before, never even reccognized.
Now we have to use. Again some clicks more... :cara_disgustada:
Do you know, is it really a system variable now or to check and for every dwg?
Cheers
0 Me gusta
RobDraw
Your not comprehending the previous posts. It is said several times that there are two variables. Read the thread again, carefully.
Rob
0 Me gusta
cadffm
It is what it was all the time, take a look into your HELP[F1], you can read it in the first lines
"System Variable" is a general expression in practise.
- File Variable (like the visretain)
- Profile Systemvariable
- Installation Systemvariable
Read more about VISRETAIN
http://help.autodesk.com/view/ACD/2021/DEU/?guid=GUID-897B1672-4E09-42E0-B857-A9D1F96ED671
and about  the "new" cool VISRETAINMODE (and the powerful XREFOVERRIDE) too.
Sebastian
0 Me gusta
BrauseFrufo
Sorry, my english is not so good, so I have not understand the of the two possibilities for visretain settings immediately
Thank you
0 Me gusta
RobDraw
VISRETIAN - Drawing
VISRETIANMODE - System
Good Luck!
Rob
0 Me gusta
