AutoCAD 2019.0.1 Update is available for download
john.vellek
Alumni Alumni
john.vellek
The latest update for AutoCAD 2019 is released today for customer download. It is available in the Autodesk Desktop App and in your account page.
The update can be applied to AutoCAD installed as a standalone application and AutoCAD-based toolsets and vertical products:
  • AutoCAD 2019
  • AutoCAD Architecture 2019
  • AutoCAD Civil 3D
  • AutoCAD Electrical 2019
  • AutoCAD Map 3D 2019
  • AuotCAD Mechanical 2019
  • AutoCAD MEP 2019
  • AutoCAD Plant 3D 2019
  • Advance Steel 2019
After applying this update, the Product Version or Built On Version in the About box will be listed as P.61.0.0 AutoCAD 2019.0.1.
For additional information, please review the attached readme file for this update.
John Vellek
john.vellek
This updates addresses the following issues:
Problems Reported Through the Customer Error Reporting Utility
General
  • Startup crashes after loading a partial CUIX file after resetting settings to default no longer occur
General Update Content
Display
  • The draw order in a block definition is maintained when inserting the block.
Editing
  • When grip editing is in progress and dynamic input is turned on, pressing the Tab key cycles between the full distance, the angle, and the extension distance.
General
  • The Open from Web & Mobile and Save to Web & Mobile buttons on the Quick Access toolbar in 64-bit versions can now be hidden or removed.
  • The division symbol in stacked fractions can now be changed between horizontal and diagonal.
  • The tool palette path can now be changed from the default value without being reset when exiting the Options dialog box.
John Vellek
