Anuncios
AutoCAD 2018 to ArcGIS Pro - Georeferencing Problem
No aplicable
When I import an already georeferenced AutoCAD 2018 drawing into ArcGIS Pro, it does not land on the correct location.
I have used the following different ways to georeference my drawing in AutoCAD 2018:
1. On AutoCAD 2018 there is a Geolocation tool in where I choose the geographic coordinate system and then start to draw. In ArcGIS I add the drawing and define the projection with the CAD Layer Tools Georeference tool to make sure its coordinate system is the same as the one I choose in AutoCAD but the drawing falls in another location way far. (To Set Geographic Location from a Map | AutoCAD 2018 | Autodesk Knowledge Network )
2. I also tried using these directions in AutoCAD and then added the drawing in ArcGIS and it did not work either
Dropbox - Tutorial Manual.pdf
I know how to manually scale and move the drawing to its correct location once it has been added into ArcGIS Pro using control points but I need the drawing to fall where I need it without me having to do it manually.
3. I keep on reading about world files but I don't understand if I still need one even if the drawing has been georeferenced in AutoCAD using the tools provided.
4. If I need a world file how do I create one?
I don't understand what I am doing wrong since both AutoCAD and GIS have the same coordinate system.
Does the problem has something to do with units?
I would really appreciate some help.
Thank you,
0 Me gusta
Responder
Soluciones aceptadas (1)
3.508 Vistas
6 Respuestas
Respuestas (6)
Alfred.NESWADBA
ArcGIS does not know the settings of that AutoCAD internal information.
So you need to tell ArcGIS which geographic coordinate system and which units you were using in AutoCAD (without the geolocation settings), simply absolute coordinates in meter or feet.
World files are only valid for raster files like TIFF, ... but not for DWG (or DXF) files.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
Thank you Alfred for your response.
When you say that I should define the absolute Geographic coordinate system I used in AutoCAD when I add the dwg into ArcGIS do you mead I should define the Projected Coordinates ?  If so, yes I already defined the coordinates in ArcGIS after importing the dwg from AutoCAD and it did not work.
In regards to World Files and rasters. I found this tutorial and it seems to be applied to dwg files. Is this incorrect how they are doing it?
https://sites.temple.edu/psmgis/2017/02/17/georeferencing-floor-plans-for-use-in-gis/
Thank you,
0 Me gusta
Alfred.NESWADBA
No, I did not mean you should define a coordinate system in AutoCAD (as AutoCAD does not have such an option, only AutoCAD Map 3D and Civil 3D are AutoCAD based products that know coordinate systems).
The workflow could be to use the coordinates in AutoCAD which are corresponding to a specific geographic coordinate system. When you then import this dwg-file into ArcGIS you need to inform ArcGIS which coordinate system and units you were thinking about when drawing objects in AutoCAD.
Well, I have not seen yet that world files can be used with DWG-files, but may be it's just me not knowing that this could work.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
What about AutoCAD 2018 Set Location tool which allows you to choose a coordinate system? (see attached picture)
Is that different than defining a coordinate system for the drawing?
0 Me gusta
Alfred.NESWADBA
ArcGIS does not support this setting, ArcGIS only ready X, Y and Z coordinates and UNITS, ArcGIS can't evaluate and geolocation settings within the dwg-file. This setting is specific to AutoCAD and not for any GIS-systems which can read dwg-files.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Solución aceptada
Thank you I realized that after many tries.
I ended up figuring out how it should be done.
For anyone else having issues with this follow these steps:
1. https://www.youtube.com/watch?v=pwT5cjK6q50.  (To georeference a drawing in AutoCAD)
2. https://sites.temple.edu/psmgis/2017/02/17/georeferencing-floor-plans-for-use-in-gis/ (To create a World File) ( Start from step 5)
3. Import into ArcGIS and it will land on the correct location. It will already have a defined projection based on the one chosen on AutoCAD.
Thanks and I hope this helps someone else!
