AutoCAD 2018 Stuck On Opening Screen
joshua.holzbach
joshua.holzbach
Recently a user has been unable to get pass the start screen for AutoCAD where they can create a new drawing, or an open existing one.  It seems to be frozen in that there is no response to anything being clicked on. They are unable to exit the program normally as well the Task Manager is having to be used to terminate the software. This is happening every single time they open up AutoCAD.
@joshua.holzbach
john.vellek has edited your subject line for clarity: Stuck On Opening Screen
john.vellek
hi @joshua.holzbach,
Are other user's on your network not having this issue? If so, what is unique to this computer/specific user?
Here are some articles that might help you get this resolved.
John Vellek
john.vellek
Hi @joshua.holzbach,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
joshua.holzbach
I managed to fix it either by resetting it back to the default settings, or by opening it as an administrator then opening normally.  I am not totally sure which actually fixed, it may have been a combination. Either way it's working now.
john.vellek
I am glad things are back to normal. Thank you for posting the possible solutions you worked through.
John Vellek
