AutoCAD Forum
AutoCAD 2018 font issue
14 REPLIES 14
Message 1 of 15
5162 Views, 14 Replies
we recently installed AutoCAD 2018 in the office and noticed that one of our templates has issues relating to the font. in the offic we have one computer that operates AutoCAD 2016 and there is no issue with our template however any newer version distorts the fonts. i have attached 2 images to highlight the differences between the two templates. as you can see in the 2018 version, the text is a different thickness and is wider.cad 2016.JPG
any help would be appreciated.
Tags (1)
14 REPLIES 14
Message 2 of 15
imadHabash
you may need to install AutoCAD 2018 updates and Hotfixes that may help . i suggest to read this AKN article that will guide you how to fix it . >> Click <<
Imad Habash
Message 3 of 15
john.vellek
Hi @Anonymous,
From the images you show, this looks as if the font is not being found or is damaged in some way.  Can you share a sample drawing and any special font(s) that are being utilized in the file?
Can you also please tell me your exact AutoCAD version by typing ABOUT at the command line?
John Vellek
Message 4 of 15
john.vellek
Hi @Anonymous,
I am checking back to see if you have been able to resolve your font issue.  If not, please send em a sample drawing file and the fonts that are being utilized so I can take a look at this problem.
John Vellek
Message 5 of 15
in reply to: john.vellek
Hi John,
Thanks for getting back to me
The version of AutoCAD I am using is O.49.0.0 AutoCAD 2018
I have attached a sample file as requested.
Regards
Message 6 of 15
nikm42Q9N
Auto-cad is not finding your fonts so its using a default as a filler. You need to go into your C drive and find your font folder if the font is not there you need to put it in the folder and open the file and install it then restart the computer and Acad should pick it up. If the font is there then reload it then restart. the only other thing is your new autocad is not looking in the right folder for fonts cause the path need to be fixed
Message 7 of 15
john.vellek
Hi @Anonymous,
Please open your Text Styles and verify that each of your styles can find the font that has been assigned.
You will see a little yellow warning symbol for those that are missing.
John Vellek
Message 8 of 15
Sorry guys for adding my question but I don't want to open a new topic.
Is there anywhere a place where I can find all available fonts in AutoCAD 2020?
I saw there is a list in Text Style window but I cannot seve it or export.
Thanks in advance for the answer!
Message 9 of 15
imadHabash
There are many websites that provide free downloadable fonts. Try to search them on Google search with search term: “true type font download” OR “shx font download”. also you can follow this video tutorial >> Click <<
Imad Habash
Message 10 of 15
Alfred.NESWADBA
You can open your Windows Explorer and go to this folder:
C:\Program Files\Autodesk\AutoCAD 2020\Fonts
There you can find all SHX fonts that are installed with AutoCAD 2020
To find TrueTypeFonts (which can also be used with AutoCAD) please look to this folder:
C:\Windows\Fonts
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 11 of 15
Dear Colleagues,
so can you help me which font should be used to display those signs?
I am attaching the source file as well.
https://a360.co/394LLl8
Message 12 of 15
I have selected these 3 characters inside the MTEXT, then used <CTRL><C> to copy, opened MS-Word and used <CTRL><V> to paste these characters into word.
Then selected the characters in MS-Word and got this font displayed:
  • Cambria Math
HTH, - alfred -
Alfred NESWADBA
Message 13 of 15
Hi Alfred,
thanks for the reply how how to display it correctly in AutoCAD? Somehow import from MS Word?
Message 14 of 15
Izhar_Azati
in reply to: nikm42Q9N
Starting with 2018(?), ACAD stop to search shx fonts, if the "Support File Search Path"s contine sub-directory of the Fonts, before the Fonts, its mask all the fonts in the parent directory.
Don't use:
C:\Program Files\Autodesk\AutoCAD 2021\Fonts\MyFonts
Use:
Message 15 of 15
Izhar_Azati
in reply to: Izhar_Azati
ShxFileNameShxFileSizeShxFileDateCrc32ShxTypeFontNameAboveBelowModes
@extfont2.shx4908812004-01-29 10:05DBECAD3ABIGFONTAUGJP-@EXTFONT2 @EXTFONT2 2004-01-271502
AcadEref.shx8232010-11-15 09:1726AF2D4AUNIFONTWD Copyright 2003 by Autodesk2172
aehalf.shx137432006-01-30 14:55B12D0222UNIFONTExtended Standard Font for UNICODE622
AMDTSymbols.shx12172010-11-15 09:179FFD7C53UNIFONTAMDT_Symbols Copyright (c) 2005 Autodesk96482
amgdt.shx52652010-11-15 09:17634EE373UNIFONTAMGDT Copyright 1996-2008 by Autodesk2172
amgdtans.shx50882010-11-15 09:17BD3F9BD6FONTAMGDTANS Copyright 1996 by Autodesk2172
bigfont.shx3242942003-12-08 17:5728AA9794BIGFONTCreated on 2/18/861522
bold.shx105502004-03-07 22:23F441A0BAFONTbold60140
Cdm.shx39302010-11-15 09:17BCA26E79UNIFONTCDM300-Font1050
CDM_NC.shx75372010-11-15 09:179D489D0EUNIFONTCDM-NC-Font50500
chineset.shx6651171997-11-18 06:365FB79236BIGFONTwith BUGS ?NULLNULLNULL
complex.shx304861998-11-21 08:07A3A38B97UNIFONTCOMPLEX Copyright 1997 by Autodesk2172
dim.shx42762004-03-07 22:24EECBF562FONTDim Simplex 5/922172
extfont.shx4365602003-11-27 16:40A90EA880BIGFONTCreated using SFCU on 29/11/90.1502
extfont2.shx4908712006-07-26 17:33C44F6D51BIGFONTAUGJP-EXTFONT EXTFONT2 2002-05-271502
exthalf2.shx301222003-07-08 17:30F4AF7D4AUNIFONTAUGHALF3042
extslim2.shx304982003-07-08 17:305B2B0C77UNIFONTAUGJPSLM3042
g12f13.shx36082010-11-15 09:17198D569AUNIFONTISO 3098.10 Proportional Spacing ISOCP1862
g13f12d.shx51312010-11-15 09:177227D9F5FONTISO40120
g13f12w.shx51162010-11-15 09:177BC23885FONTISO40120
gbcbig.shx9028411999-01-13 13:1818183FBABIGFONTַ 1998.1 FAW/Autodesk CTC CBX(0293)0642
gbeitc.shx49112006-02-08 13:44AD1400D7UNIFONTProportional Spacing ISOCP48120
gbenor.shx51862006-02-08 13:443981D824UNIFONTISO 3098.10 Proportional Spacing ISOCP48120
GENISO.shx237782010-11-15 09:17777F1B6BNULLwith BUGS ?NULLNULLNULL
geniso12.shx36082010-11-15 09:17198D569AUNIFONTISO 3098.10 Proportional Spacing ISOCP1862
GENLTSHP.shx772010-11-15 09:1734ACD97ASYMBOLNULLNULLNULLNULL
GENPRESE.shx16102010-11-15 09:17329F307BFONTunsichtbarer Zeichensatz fuer Genprese622
gothice.shx379231998-11-21 08:350E1D852FUNIFONTGOTHICE Copyright 1996 by Autodesk2172
gothicg.shx366181998-11-21 08:35C88D4A87UNIFONTGOTHICG Copyright 1996 by Autodesk2172
gothici.shx337411998-11-21 08:36A1C7BC80UNIFONTGOTHICI Copyright 1996 by Autodesk2172
greekc.shx114191998-11-21 08:3650E16242UNIFONTGREEKC Copyright 1997 by Autodesk2172
greeks.shx80891998-11-21 08:36E201B1BBUNIFONTGREEKS Copyright 1997 by Autodesk2172
hand1.shx96772004-03-07 22:24F1BBB2D6FONTHAND160100
iges1001.shx44412010-11-15 09:1787F993D2FONTIGES Font 1001 (C) Copyright 1989-91 by Autodesk2172
iges1002.shx44372010-11-15 09:17979D8C16FONTIGES font 1002 (C)1989 Autodesk2172
iges1003.shx44322010-11-15 09:1763B2D608FONTIGES Font 1003 (C) Copyright 1989-91 by Autodesk2172
ISO.shx40632010-11-15 09:173712B04FFONTISO1862
isocp.shx73222007-09-20 16:07E19CBE4AUNIFONTISOCP Copyright 1996-2003 by Autodesk40120
isocp2.shx72712003-11-18 10:257C5368D2UNIFONTISOCP2 Copyright 1996-2002 by Autodesk40120
isocp3.shx72712003-11-18 10:2511BCD22AUNIFONTISOCP3 Copyright 1996-2002 by Autodesk40120
isoct.shx72432003-11-18 10:256E5DDC36UNIFONTISOCT Copyright 1996-2003 by Autodesk40120
isoct2.shx72432003-11-18 10:253CCA9EC6UNIFONTISOCT2 Copyright 1996-2003 by AAutodesk40120
isoct3.shx72422003-11-18 10:25C2E0B8EDUNIFONTISOCT3 Copyright 1996-2003 by Autodesk40120
italic.shx273251998-11-21 08:376C024F9CUNIFONTITALIC Copyright 1996 by Autodesk2172
ITALIC8.shx272562010-11-15 09:17F1D3DD09UNIFONTExtended Italic Complex for UNICODE2172
italicc.shx266251998-11-21 08:370817B2A0UNIFONTITALICC Copyright 1996 by Autodesk2172
italict.shx377091998-11-21 08:370F88DB16UNIFONTITALICT Copyright 1996 by Autodesk2172
monotxt.shx88161998-11-21 08:380FEC60E4UNIFONTMONOTXT Copyright 1997 by Autodesk622
MONOTXT8.shx151842010-11-15 09:175CBB51ABUNIFONTExtended Monospaced Standard Font for UNICODE622
romanc.shx230571998-11-21 08:38E25728BEUNIFONTROMANC Copyright 1996 by Autodesk2172
romand.shx225341998-11-21 08:389301DD77UNIFONTROMAND Copyright 1996 by Autodesk2172
romans.shx160862004-10-12 13:4966638106UNIFONTROMANS Copyright 1997-2004 by Autodesk2172
romant.shx397281998-11-21 08:38DD51118FUNIFONTROMANT Copyright 1996 by Autodesk2172
scriptc.shx265871998-11-21 08:3930990132UNIFONTSCRIPTC Copyright 1996 by Autodesk21122
scripts.shx202441998-11-21 08:3904A7B426UNIFONTSCRIPTS Copyright 1996 by Autodesk21122
SIMPLEX8.shx138132010-11-15 09:172F6F01C2UNIFONTExtended Roman Simplex for UNICODE2172
spec_bar.shx17672004-03-07 22:24B01BBDCFBIGFONTSPECIALS2172
spec_sl.shx15362004-03-07 22:2414251741BIGFONTSPECIALS2172
special.shx15362004-03-07 22:2414251741BIGFONTSPECIALS2172
syastro.shx68411996-11-20 20:5119DD7643FONTSYASTRO Copyright 1996 by Autodesk2172
symap.shx61491996-11-20 20:51B3C0B8C9FONTSYMAP Copyright 1996 by Autodesk2172
symath.shx60701996-11-20 20:5132C5249AFONTSYMATH Copyright 1996 by Autodesk2172
symeteo.shx50841996-11-20 20:51F835143AFONTSYMETEO Copyright 1996 by Autodesk2172
symusic.shx69441996-11-20 20:51D5EAD771FONTSYMUSIC Copyright 1996 by Autodesk2172
times.shx333892004-03-07 22:2453C85354FONTTIMES120200
timesout.shx157032004-03-07 22:245E66819DFONTTIMESOUT120200
txt.shx84892000-03-17 14:530BEAAF25UNIFONTTXT Copyright 1997-1998 by Autodesk622
whgdtxt.shx2236991998-01-24 05:25DB30F8F3BIGFONTJin-Hangul Header Dec/90 by GID9602
whgtxt.shx1960691998-01-24 05:256502D1A6BIGFONTJin-Hangul Header Dec/90 by GID9602
whtgtxt.shx6482111998-01-24 05:25306014F0BIGFONTHangul AutoCAD font By BAI NAK HYUN-1602
whtmtxt.shx9166321998-01-24 05:252AF224B9BIGFONTHangul AutoCAD font By BAI NAK HYUN-1602
Tags (4)
AutoCAD Inside the Factory
