AutoCAD 2018 fatal error
hi,
i got this message during working on autocad
fatal error: unhandled access violation reading 0x0000 exception at 840d5787h
and right after it the program crashed.
does anyone know what should i do?
Alfred.NESWADBA
With a specific dwg-file or also with other files?
Does that happen for a specific command or dialog?
If you have not done any customizations you might try to reset settings to default (>>>details<<<)
Please start these 2 commands: _ABOUT and _GRAPHICSCONFIG and show us the screenshot of these dialogs.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
hi,
here are the screenshot that you asked.
is everything configured as it should?
Alfred.NESWADBA
thank you for your screenshots, AutoCAD is up-to-date, your graphic card driver is newer than mine (also newer can be an issue, my driver version is 416.81 and that works well).
In case you have a laptop and the vendor has own drivers for their version of GTX1050 you might have more success with that vendor specific driver.
These questions are open from my side:
- alfred -
Alfred NESWADBA
