Anuncios
Autocad 2018 exporting and importing files.
No aplicable
Have made a couple of modes in Autocad 2017 and they ca be successfully imported into 3ds max 2016 . On installing Autocad 2018 same models when saved in 2018 version won,t import into 3ds Max 2016 ?  Also i found that Fbx export does not want to work either in Autocad 2018?
0 Me gusta
Responder
Soluciones aceptadas (1)
859 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
It depends on how you import the AutoCAD model into 3DS-Max, if you use the DWG-file then no, AutoCAD 2018 uses a new dwg file format and that new format is not known to 3DS-Max 2016.
You might try command -EXPORTTOAUTOCAD and chose the DWG2013 format .. .that should be working well with 3DS-Max 2016.
What means "does not work" ... what do you do and what is the result, which messages do you get, ...?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
Go back to AutoCAD2017 or upgrade to 3DSMAX2018 if you want the best exchange options between the two programs.
0 Me gusta
