AutoCAD 2018 crashes randomly
No aplicable
the program crashes when I try to go to a different camera mode. Also if it didn't crash yet then when I try to render in that view then it crashes too. I deleted the program entirely and re-downloaded everything and same things happen. I tried to "wblock" the entire project and create a new project. I am finally done and ready to render and I cannot move forward. If someone can help I'd appreciate it. This is the error that comes up every time.
0 Me gusta
Responder
331 Vistas
2 Respuestas
Respuestas (2)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Have you run AUDIT on your drawing file(s)? There might be some corruption.
  • Please also tell me your exact AutoCAD version (type ABOUT at the command line)
  • Windows version (type WINVER at the Windows command line)
  • Graphics card make and model
I suggest making sure that your AutoCAD is fully up-to-date using your account page or the Autodesk Desktop App.
Please check that Windows is fully updated
Please check to see if there is a newer driver for your graphics card.
John Vellek
0 Me gusta
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
