AutoCAD 2018 and Land Desktop 2006 Object Enablers
I received a drawing from a customer of our's who apparently is a little behind the times and uses Civil 2006 and Land Desktop 2006. I am running AutoCAD 2018. Needless to say, there were a lot of proxy graphics when I opened up the drawing.
I was able to install the Civil Object Enabler with no problems; the Land Desktop seems to be a different beast. Upon installing this, I get an error message saying that "Setup did not detect a valid version of Autodesk Object DBX on this machine" and "Installation ended prematurely because of an error" when I press OK.
What am I doing wrong? Is there something else I can install to alleviate the error messages? Will a newer version of the object enabler that I can use that will still work for 2006? There are some 900+ objects in the drawing that I can't see because of the issue and I cannot get any help from the customer's side of things as there are, like I said, I little behind the times and unfamiliar with anything less than 10 years old.
