>> dwg is currently in use or is read-only. Would you like to open the
>> file as 'read-only
In that case I guess either the file or the folder or the network security does not allow to overwrite the file.
It does not have anything to do with the release of AutoCAD which saved/created that file.
Try to open such a file with the option "read-only", then start command _SAVEAS and give the file a new name, close the file and try to reopen it ... do you again get this info about "in use..."?
Try this twice, one time saving to the original folder and another time with saving the file on your local system into a temp folder.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
