AutoCAD Forum
AutoCAD 2017 - Wipeout Lag Bug
41 REPLIES 41
Message 1 of 42
nrz13
4288 Views, 41 Replies
In AutoCAD 2017, when moving, copying, drawing, etc. over a wipeout with many vertices, the program completely bogs down and becomes unresponsive for several minutes.  This behavior is similar to what was experienced in AutoCAD 2015 and 2016 with dense hatches and may be related, but I did not experience this problem with wipeouts in either 2015 or 2016.
In the attached drawing, try to move or copy the line to the right through the areas with the circles (where the vertices are densest).  Be prepared to hit the ESC key a dozen times unless you have time to wait.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
41 REPLIES 41
Message 2 of 42
pendean
in reply to: nrz13
I can't repeat your problem in R2016 or R2017 and I widened your wipeout to test it. Did I miss something?
Message 3 of 42
nrz13
in reply to: pendean
Like similar issues in 2015 and 2016 with hatches, it may be dependent upon variables being set a certain way.  Here's my GRAPHICSCONFIG:
I retested it and it's not as bad as it was before, but still bad.  I'm not sure what's controlling that.  You might have to wave the line around over the dense wipeout area a few times for it to stick.
Message 4 of 42
Partenheimer
in reply to: nrz13
Like Dean, I also could not get the line to stick.
Michael Partenheimer
Message 5 of 42
Alfred.NESWADBA
in reply to: nrz13
am I right that this hang-up's only appear while moving the line and havingobject snap INTersection active?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 6 of 42
nrz13
in reply to: Alfred.NESWADBA
Partway there, Alfred.  The lag only appears when Apparent Intersection (≈80% of the lag) and Intersection snaps are turned on.  Good catch.
Message 7 of 42
nrz13
in reply to: nrz13
I'm not sure who marked this thread solved, but it definitely wasn't me.  This is a bug that was not present in previous versions of AutoCAD.  It's similar to bugs that were eventually fixed in 2015 and 2016 that dealt with delays and Intersection OSNAPS.  I definitely want this solved in 2017 as well.
Message 8 of 42
Ron-C
in reply to: nrz13
Maybe if you set AutoCAd 2017 to use DirectX 11 may help.
I can not reproduce your problem.
Win 7 enterprize 16g RAM  Firepro 3900
Message 9 of 42
nrz13
Alfred:
Were you able to reproduce this, or were you just guessing based on previous similar problems?  If you experience this, are you also running an uncertified NVIDIA card?
Message 10 of 42
Alfred.NESWADBA
in reply to: nrz13
Having object snap INTersection active ... yes, I can reproduce hangups.
Yes, but that happens also with hardware acceleration OFF, so using the AutoCAD internal software driver. Therefor I'm sure it's not depending on certified or not certified.
But just saw that additional important setting: it only happens when dynamic input is ON, and with the same setting (dyn. input ON) I can reproduce the same lag's also with 2016.
I have not seen that as I don't have dynamic input active by default, just in 2017 as it's fresh installed and not all settings are done.
And again yes, when the wipeout-objects are deleted then no delay during moding the line over the existing objects.
- alfred -
Alfred NESWADBA
Message 11 of 42
nrz13
Hmmm, that seems to confuse things even more because on my 2016 install (work computer), I can't reproduce it with hardware acceleration on or off.  I'm running SP1, but I'm guessing you are too.
I'll have to try with and without hardware acceleration on my home computer tonight to see if it behaves any differently.  I'll also look into DX11, although I believe I looked into that in the past and couldn't figure out how to get it to use DX11 (even though it's a DX11 card).
Message 12 of 42
Alfred.NESWADBA
in reply to: nrz13
Having dynamic input ON?
- alfred -
Alfred NESWADBA
Message 13 of 42
nrz13
Yes, sorry I should have mentioned that.  I only ever use dynamic input (no command line).
Off topic:  I used to hate dynamic input, but I gave it a shot for a couple of days because I knew it to be more efficient since your eyes can stay focused on where you're drawing rather than darting back and forth from the command line.  After giving it an honest try for two days, I've never gone back.  You probably also know that you can adjust the placement for the dynamic input box that pops up.
Message 14 of 42
nrz13
in reply to: nrz13
I did some more testing tonight and determined that hardware acceleration makes no difference for me.
However, Dynamic Input did make a difference.  As far as I can tell so far, to reproduce this bug, try the instructions in my first post with:
- Dynamic Input on
- Apparent Intersection and Intersection OSNAPs on
Message 15 of 42
Partenheimer
in reply to: nrz13
I've attempted several setting changes in an effort to recreate the lag issue in your drawing and have still been unable to recreate it.
I did apply Hotfix 1 to my installation of AutoCAD 2017 yesterday.
Work: Win7 64bit, i7 3.5Ghz, 16GB RAM, AMD FirePro W5000 2MB, Dual Samsung LCDs @ 1920x1200, Samsung 250 GB SSD, Seagate 2TB HD
Message 16 of 42
nrz13
in reply to: Partenheimer
I plan on installing the Hotfix tonight and will report back.  Thanks.
Message 17 of 42
pendean
in reply to: nrz13
R2017 Hotfix 1 only addresses these items:
The following issues are addressed by this hotfix:
Layers of Xrefs that are frozen in viewports are plotting ellipses.
In some languages the model documentation commands are not working.
The number of hits for GetLineContainment is incorrectly counted.
Xrefs show as needing reloading when opened from a network path to a shared folder.
http://up.autodesk.com/2017/ACD/Autodesk_AutoCAD_2017_Hotfix_1_Readme.html
Message 18 of 42
nrz13
Thanks for the additional info.  All the same, I'll still try it out in case fixing one of these other bugs happens to fix this one too (unlikely, I know).
Message 19 of 42
NeutronStar13
in reply to: nrz13
With ACAD 2017 and a Quadro K2200M video card I also can't repro the issue.
I turned on ALL the osnaps, and all the other settings everyone mentioned, and the only sticking I could get was for about a tenth of a second when it hit one of the osnaps
Message 20 of 42
Hello nrz13;
I tried to reproduce the issue on my system, but was unable to do so.
I have AutoCAD 2017 with no hotfix installed, Windows 7 Enterprise, i7 4900MQ 2.8GHz, 16GB RAM, and a Nvidia Quadro K2100M video card.
I tested with all Osnaps on, Dynamic input on.
I noticed the 680 MX isn't listed on the Certified Hardware site. Have you installed 2017 on the work system yet and tested it there, to see if it might be related to using the uncertified card?
Steve Tamplen
Technical Support Specialist
”Boost
