AutoCAD 2017 stalls at "loading" on spashscreen
No aplicable
The software is stalling or lagging on the the splashscreen. It seems to start stalling at the same point everytime. It stalls at "loading" right after "opening drawing... *.dwg" and "loading... vl.crx". It stalls here and will not start the program. I tried deleting the ADSKFLEX_NUMBERS_TSF.data file as suggested for a very similar issue, but it didn't help. I have been using it just fine offline. The problem started right after I tried to used it while connected to a network.
0 Me gusta
Responder
608 Vistas
4 Respuestas
Respuestas (4)
Darin.Green
Try reseting your application profile as well as clearing your user authentication & temp directory...
  1. On your computer, navigate to:
    • ​​C:\ProgramData\Autodesk\CLM\LGS\<product key>_<<product version>>\
  2. Delete the LGS.data file.
  3. Navigate to
    • C:\Users\<username>\AppData\Roaming\Autodesk\
  4. Delete the ADUT folder and it's contents
  5. Start the application.
If this information was helpful, please consider using the Accept Solution
0 Me gusta
edwin.prakoso
So AutoCAD opens normally when not connected to the internet?
You may want to check the firewall and anti-virus. Try to disable them and see if it will run normally.
Try to disable them to narrow down the problem.
Cheers,
Edwin Prakoso
0 Me gusta
No aplicable
It didn't help.
Sent via the Samsung Galaxy S® 6, an AT&T 4G LTE smartphone
0 Me gusta
No aplicable
After the issue started, I haven't been able to use it online or offline.
0 Me gusta
