Autocad 2017 Crashing Frequently and unexpectedly
I urgently need help:
I have been an Autocad user for several years now, and have experienced very little in the way of problems and crashing while using the software. Recently, I purchased a new Windows computer to replace my "frankenmac", a MacBook Pro that ran exclusively Windows specifically to allow for use of Windows-based Autocad. I also have been running Autocad 2017 on a 6 year old Lenovo T510 that I keep around as a backup, and Autocad actually ran better on the Lenonvo than the Mac despite being several years older, and having a much slower processor. The reason for the upgrade came with the desire to integrate more 3D CAD into my work, and neither on my older machines having the balls for large 3D drawings, or really, any drawing with more than one Xrefed DWG Attached.
Currently I am engineering a theatrical production, piece by piece in AutoCad. I have master drawing that shows the whole show in 2D only, and then a separate drawing for each individual piece, each of which includes a 3D model. Here is where my problem comes in: While drafting in 3D, at some point in every drawing, I experience software crashes. What I am doing at the time is not always the same though many times it occurs while deleting an object or 2D lines, etc. Nearly every thime I atleast get the opportunity to create a recovery file, so I can reload and return to work, but it is getting more frequent, and much more frustrating, and occasionally I do not get the opportunity the save a backup, often leading to losing work. When this occurs I get an error message that says the following:
"fatal error unhandled access violation reading 0x4abde000 exception at 38ed2632h"
Initially I had suspected this was an OS issue attached to my OEM (read: bloated) version of Windows 10 (initially Home Edition, then upgraded to Education Edition). I should not that I was having some software issues with Microsoft Office as well, along with a Bluetooth Driver issue, so naturally I thought that a wipe and clean reinstall of the OS would solve all my issues. I went ahead and installed a fresh copy of Windows 10 Pro on the machine a few days ago hoping it would help, but despite an overall positive boost in system performance, have seen no change in my AutoCad Problem, and I would say it may be getting worse.
My system specs are as follows:
Model: MSI GS63VR
Processor: Intel Core i7 6700HQ
Graphics: Nvidia GTX 1060 with 6gb dedicated RAM (DDR5)
Memory: 16gb DDR4
On a final note, I sent a drawing to one of my professors yesterday so that he could look it over, and experienced the same crash as I was on a different machine. Whatever my issue is seems to be attached to the individual files in this case.
Whatever is the cause here I need to solve it ASAP, as my show is mid-build, and I need to finish drafting it without having to recover my drawings constantly.
Thanks.
