Anuncios
AutoCAD 2017 crashes randomly while in use.
No aplicable
I recently downloaded the Student version of AutoCAD 2017 for Win. 7 64-bit so I can do some of my engineering work while in my free time. However the program crashes randomly while I'm in the program and drawing things out. It will FREEZE UP, THE SCREEN WILL GO BLACK FOR TWO SECONDS, THEN POP BACK UP FROZEN WITH AN ERROR MESSAGE OF A DRIVER CRASH. I'm running on dual 280Xs with an Intel-i7 4790K, and I have never had real problems with this computer. I know that there were AMD issues with the 2016 version, and I tried downloading new driver stuff from AMD and switching to Windows Basic, but to no avail.
So any ideas? I'll do what it takes to fix it, even if it means a clean install or something similar
Thanks!
Also here is a picture of what's happening if that helps.
Ok well now it's showing as an Unhandled Access Violation
0 Me gusta
Responder
Soluciones aceptadas (1)
574 Vistas
4 Respuestas
Respuestas (4)
ennujozlagam
@Anonymous hello, try to updates your graphics card driver to the latest or try to switch off your hardware acceleration and see if this helps. thanks
and also try to install latest updates and service packs from autodesk.
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
This sounds like a graphics card driver problem. i suggest that you check to see if you have the most current.  In addition you can test this by running the /nohardware switch when launching AutoCAD. This will disable hardware acceleration at startup.
John Vellek
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
