Anuncios
AutoCAD 2016 will not open when .dwg file is double-clicked
No aplicable
I am using Windows 7 professional.  I removed all my previous versions of Autocad using the windows add/remove program . I then downloaded and installed Autocad 2016. I can open drawings from within autocad or by dragging the file to the Autocad shortcut on the desktop. If I try to open a drawing by double clicking or a right click and select open like I could in previous versions, I get an error message that it cannot find the autocad 2015 exe. Dwd Launcher is set as the default to open the program. I tried a repair and a reinstall.  When I go into the registry, I see autocad 2015 not 2016. I suspect that this is the problem but I am not knowledgeable enough to try and edit the registry. I am attaching images of the error., the default program and the registry. Allan Daschuk
Responder
Soluciones aceptadas (2)
33.128 Vistas
24 Respuestas
Respuestas (24)
No aplicable
Thanks Edwin
The file worked!
I was moving from Civil3d2014 to Civil3d2016.  It kept opening up 2014 verison and as soon as i dbl clicked the reg key and clicked yes I then opened a dwg file and it worked with the 2016 version.
0 Me gusta
No aplicable
Please help me I installed auto cad 2016 in my windows 10. For the first time its work after that when I open and I can't select any thing when i click open drawing it seems like stucked and in ash colour how to fix this issue please help
0 Me gusta
No aplicable
weird, dunno.
Sounds like a different problem all together.
You might want to consider searching for something similar or start your own thread.
0 Me gusta
No aplicable
I've done the above procedure but still didn't work and showing the error.
0 Me gusta
jweiss1313
Try to open all your AutoCAD related applications.  AutoCAD and DWGtrueview and AutoCAD Mechanical is you have this too.  I found that if you have the DWGtrueview viewer application you must open it as well so it registers properly.  This have fixed the issue for my AutoCAD users.  Occasionally I had to run the AutoCAD register file attached to this thread.
John C Weiss Jr.
CAD Manager
Follett LLC.
0 Me gusta
