AutoCAD 2016 VERY slow with XREFs
No aplicable
was there a solution to this problem? I am having the same issue with xrefs and a lag in commands. I have tried purging the xref drawing with no luck. I feel like i am spending more time waiting than doing work.
0 Me gusta
Responder
2.822 Vistas
2 Respuestas
Respuestas (2)
john.vellek
Hi @Anonymous,.
There are a few things that can be examined to remedy this behavior.
  • First take a look at Xrefs and nested Xref files to make sure that they are clean and stable <see article>
  • Check to make sure that you have installed hotfixes and service packs from here.
  • Move all the files to your local drive to verify that your network path to them is not the issue.
  • Verify all the locations stored in your file paths (in Options) are valid and can be reached. A bad path can cause some lag.
  • Take a look at Task Manager to see what else is running. Security software might be interfering
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
0 Me gusta
