Is there a way to turn off the new feature that is adding a comment to my PDF for every SHX font text object? I am happy with searchable TTF but this PDF comment change is not beneficial to me and floods the comment list with useless information.
Commenting because I'd also like to know the solution to this problem. According to the help files SHX fonts are always converted to geometry and the text is copied into the file as a comment. No mention on how to disable this feature.
@Anonymous wrote:
... if there was a reason to add this functionality then there should be a setting so that it can be turned off....
that ought to be rule for any and every new feature that gets added. Whether it's Infocenter, the Start tab, or the SHX Comment feature.
but don't blame the devs so much as mgmt & marketing, who seem to think showing off the latest bling is _the_ important thing
From the outside in, keeping existing features alongside new features *sounds* like a good idea. But digging a little deeper some problems start jumping out.
Continuously retaining the old legacy code leads to bulky, overweight programs which are both larger, taking more disc space, and requiring more work to diagnose and update. Where problems exist, for every old/new option that doubles the potential paths to tracking down problems.
New features would be expected to work with old data, so not only do they have code for dealing with new data they must somehow work around the old data as well. Or at least gracefully inform the user "I can't do that, Dave". Although even that may be seen as ungraceful by some users.
The oldest features are based on tools and frameworks which are being deprecated in the newest operating systems. This means that those old features may simply not be feasible with new releases.
Not to say that all of these apply everywhere, all the time. But there are reasons for RISC (reduced instruction set computing) style of development.
So what's the solution?? I can turn them off in my own Adobe software, but I cannot dictate what the client does with their software. Is there way to turn off the comments for everyone without altering Adobe viewer software...
at this point, it seems that the only way to avoid the problem is to cease & desist using shx fonts for text.
That's not a good answer.... but the approach taken to make SHX text searchable in a PDF doesn't work. More and more it's becoming obvious IMO that Autodesk's decision to deprecate DWF is a poor decision for customers, collaboration, and communication.
@JGerth
In my opinion it isn't strange that Autodesk shifted to pdf. The world is bigger then Autodesk and in my experience outside the hardcore Autocad user nobody even knew what a DWF was.
But if you shift to pdf you have to do it right. It took years until our company didn't need another application to make pdf's in a way we could present our pdf's to clients. And even with Autocad 2014/2015 we sometimes still use external software to make sure clients see and print the pdf correctly.
But Autocad 2016 is a step back for that matter. We depend highly on shx bigfonts and we don't want unexpected boxes around text when a client opens a pdf. When clients see those boxes they start asking questions and that is not something you want as a company. It is bad publicity.
Autodesk used to be one of the more reliable software company's. New features did work and and didn't have unexpected side-effects for users who didn't want them. But in recent years this has changed and Autocad 2016 doesn't make me very optimistic.
