- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I recently upgraded/migrated to AC 2016 from AC 2014 and the resoltion on screen has deteriorated noticably. From R.14 I have uopgraded several times, and have never had any issues with line and text resolution. With 2016, the geometry and text is not nearly as crisp as in prior versions. I am using a Viewsonic VA2465Smh monitor. It has full HD 1920 x1080 resolution, running at 60pHz refresh rate. I have it connected to the HDMI input connected to a DVI port on an Intel 46000 HD integrated video card. I am running Acad on a a fairly new Windows 7 workstation with an Intel core i5 64 bit motherboard. My system far exceeds the minimum system requirements as stated by Autodesk.
I have been told that the Autodesk techincal hlp is not an option becuase I don't have an Approved/Recomended graphics card. I am hestitant to invest in a new graphics crds, since I am not sure that is the problem. In an effort, I recently installed the following graphics card:
Nvidia GEForce GTX 750
1 GB GDDR5 main memory
128 bit memory bit width
80 GB/s memory bandwidth
1020 MHZ base clock
OpenGL 4.4 Support
DirectX 9 thru 11 enabled
Windows 32 and 64 bit vista to 8.1 support Up to 3 monitors supported
240 HZ max refresh rate
The Nvidia card made no improvement in resolution, and in fact may have been a little worse. I am hesitant to invest in a 4k monitor as a trobleshooting step due to the steep price tag. I was wondering if anyone esle experienced this problem and what the resolution was. Why am I suddenly encountering this issue on 2015-2016 versions. I like the AC 2016 interface, but for the time being I am back using 2014.
Michael Smith
¡Resuelto! Ir a solución.
