AutoCad 2016 Rev Cloud arc setting keeps changing
kgroskopf
kgroskopf
I am having an issue that just started recently in my autocad 2016 and many of my co-workers are having the same problem.
When you create a polyline or box etc. to change into a rev. cloud typically all you needed to do was change the arc setting one time and it stuck the rest of the time.
Now in between every rev clould my arc setting goes back to some ridiculous size.
Any ideas?
0 Me gusta
Responder
399 Vistas
2 Respuestas
Respuestas (2)
john.vellek
Hi @kgroskopf,
REVCLOUD stores the last used arc length in the system registry.  So is it possible that you have an add-in or lisp routine that is altering this?
Are you a local administrator on your computer? Please tell me if you have applied the service pack and other updates for your product and also which operating system is in play.
I assume from your description, that this is happening all drawings.
If you log in as a brand new (administrator) user does the problem still exist?
John Vellek
0 Me gusta
john.vellek
Hi @kgroskopf,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
