the first opening Autocad
quick dialogue properties (variable QPMODE set 1) appears correctly
after a couple of selections stops show
I tried to change settings QPMODE
I tried to change the default selection mode
nothing done the dialogue quick properties still does not appear
Performed a new Autocad (contemporary to the first)
I tried to open more dwg simultaneously and
and the mask occurs normally
furthermore also the select 25001 entity
dialogue disappears (but removing an entity he returns)
and in the properties bars
indicates that nothing is selected
while in the first Autocad nothing changes
any suggestion is welcome
Marco
edit
dialog disapper also 2nd Autocad
when modify propriety (change layer)
after some work time
Solved by rpharoah. Go to Solution.
>> dialogue disappears
Goto _OPTIONS ==> (tab) Selection ==> change the value Object limit for Properties palette from 25000 (which is default) to 0 ... does it work than as you like?
- alfred -
thanks for the tip, I had not memory that there was,
I increased the limit max entities editable (32000)
this work
but is not the solution to the main problem
the quick prop dialogue remains missing
Marco
QProp or Quickproperties problems
I verified that the Quickproperties dialog disappears always
after executing command bedit
message for Autodesk developer
config
S.O. Win 8.1 64 latest security pach applied
graphic board Quadro 1800 driver from site Autodesk
Processor AMD 8core no overclock
Motherboard Asus M5A97 R2 - 32GB
Marco
>> I increased the limit max entities editable (32000) this work
You can set that to 0 so you don't have any limit, it will work always, independent from the number of objects you have selected at all.
Not when I try it. Look to the video, am I doing anything different to you?
At least you might use a new feature for 2016 which let's you scan all changes to systemvariables: Use command _SYSVARMONITOR (>>>details<<<), activate all sysvar's to be monitored (just for test period, not forever) and see which sysvar's changed before you get the situation that QuickProperties don't pop up.
- alfred -
I do not know but on my system
happens what I wrote
only variable changed
lastpoin
that is irrelevant
thanks for the reply
but the problem remains
Marco
Hi.
I have had the same problem. My quick properties would not show up after hitting the "close block editor" button.
I would need to close the program and restart to get it back.
However, I found that if I modify a block while having the ribbon turned on, and hit the "close block editor" button,
all is fine. Also, if I type "BC" (BCLOSE) at the command line, the quick properties behaves. (with or without the ribbon on).
Hope this helps.
Robin.
tried too quickly
trick will work only if there aren't visibility parameters
(I have always in my blocks)
in that case the problem remains
I am waiting for definitive solution from Autodesk developers staff
In that case you have to create a case in your subscription center, because that forum here is more "users help users".
And in the same way you need a "definitive solution" think about they need something similar to you: they need a "definitive reproducable situation", so as not too many people can recreate the situation try to describe it as best what steps you exactly do and how's your GUI/workspace configured (like no Ribbon active, happens only with some of your blocks, ...).
Good luck, - alfred -
