AutoCAD 2016 Problems loading drawing
I have worked on the drawing all morning, saved the drawing and sutdown AutoCAD.
Came back after lunch opend AutoCAD and the relevant drawing, the drawing starts to load and hangs after 49% of the drawing is loaded, let=ft the drawing loading for 30mins but still at 49%.
The drawing is made up of quite a few X-REFS and all but one loads in to AutoCAD, one, however, seems to hang so i assume that this on is the problem.
Is there any way of extracting the damaged X-REF from the drawing?
Can any one help me?
Regards
Colin Davis
pendean
Community Legend
Community Legend
Start AutoCAD alone, then use RECOVER command to open the damaged file (or use RECOVERALL command on the top most file).
Thank you for your response, The drawing loads up and freezes after valid objects 22432 invalid objects 0.
Colin Davis
Colin Davis
Dicks Electrical Installations Ltd.
WINNALL VALLEY ROAD, WINCHESTER, HAMPSHIRE, SO23 0LR
TEL: 01962 841441 FAX:01962 840730
MOBILE - 07436531018
E Mail - cd@dickselectrical.co.uk
The information in this e mail, and any attachments is confidential and maybe subject to legal professional privilege. It is intended for the attention and use of named addressees. If you are not the named recipient, or person responsible for delivering this information to the intended recipient, please notify the sender immediately. Unless you are the intended recipient or his/her representative you are not authorised to and must not read, copy distribute or retain this message. It is a condition of our supplying the file to you that, any liability on our part in respect of, or arising directly or indirectly out of any virus, is excluded. Therefore run virus checking software and check the file thoroughly before opening it.
Dicks (Electrical Installations) Ltd Tel +(0)1962 841441 E Mail: postmaster@dickselectrical.co.uk
pendean
Community Legend
Community Legend
Open a blank empty file and see if INSERT command will let you get it all.
No inserting the drawing still freezes.
Emmsleys
@Anonymous
Could you attach the file drawing to the thread so we can take a look at it?
If the file is to big I can send you a BOX invite.
Sarah Emmsley
Technical Support Specialist
