when try to run application, it is just crashing and after looking into event logs, I found the following details.
please help....
Log Name: Application
Source: Application Error
Date: 23/06/2015 1:17:23 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: D5WBB6S1.hastie.local
Description:
Faulting application name: acadlt.exe, version: 26.1.49.0, time stamp: 0x54d461f7
Faulting module name: OGSCertificationUtility-6_3.dll, version: 6.3.0.14, time stamp: 0x5488c0d3
Exception code: 0xc0000005
Fault offset: 0x00018087
Faulting process id: 0x24d8
Faulting application start time: 0x01d0ad674bfc6427
Faulting application path: C:\Program Files\Autodesk\AutoCAD LT 2016\acadlt.exe
Faulting module path: C:\Program Files\Autodesk\AutoCAD LT 2016\OGSCertificationUtility-6_3.dll
Report Id: 8dc03497-195a-11e5-b290-c01885d7b4fa
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-06-23T03:47:23.000000000Z" />
<EventRecordID>96916</EventRecordID>
<Channel>Application</Channel>
<Computer>D5WBB6S1.hastie.local</Computer>
<Security />
</System>
<EventData>
<Data>acadlt.exe</Data>
<Data>26.1.49.0</Data>
<Data>54d461f7</Data>
<Data>OGSCertificationUtility-6_3.dll</Data>
<Data>6.3.0.14</Data>
<Data>5488c0d3</Data>
<Data>c0000005</Data>
<Data>00018087</Data>
<Data>24d8</Data>
<Data>01d0ad674bfc6427</Data>
<Data>C:\Program Files\Autodesk\AutoCAD LT 2016\acadlt.exe</Data>
<Data>C:\Program Files\Autodesk\AutoCAD LT 2016\OGSCertificationUtility-6_3.dll</Data>
<Data>8dc03497-195a-11e5-b290-c01885d7b4fa</Data>
</EventData>
</Event>
So you can't get LT to start/run at all?
Have you ever been able to start/run LT at all?
Try a repair installation and if that doesn;t work do a complete uninstall and clean reinstall.
