AUTOCAD 2016 FATAL ERROR
No aplicable
WHILE I WAS TRYING TO INSTALL AUTOCAD 2016 MY PC SHUTDOWN . AND WHEN I RESTARTED PC  N TRYED TO START APP IT WOULDNT START, SO I UN- AND TRYED TO REINSTALL THE  PROGRAM. BUT NOW POP-UP MESS. POPZ UP SAY'N AUTOCAD 2016 COULD NOT BE FOUND ON THIS COMPUTER, TO FIX REINSTALL AUTOCAD 2016 ... SO I TRYED N RETRYED, N THEN THOUGHT,   I AM REINSTALL WITH A FRESH DOWNLOAD... THE PROBLEM SHOULDN'T AND IS A BIG INCONVENANCE.... IF ANYBODY HAS A VAID WAY TO FIX THIS , PLEASE SHARE....
0 Me gusta
Responder
Soluciones aceptadas (2)
1.244 Vistas
6 Respuestas
Respuestas (6)
jasmin.gonzalez
Hi @Anonymous and welcome to Autodesk Community!
Sorry about the issue you are having.
I escalated your issue to our product support team on case 12147327 and they will be contacting you directly through the case.
Thank you for your patience.
Jasmin Gonzalez
john.vellek
Solución aceptada
Hi @Anonymous,
Welcome to the Community!
I am sorry that you are having problems installing AutoCAD 2016.
  • I suggest that first, you perform a clean uninstall per this AKN Article
  • Then I suggest re-downloading the application installer using the Virtual Agent
  • Please also review this post regarding Best Practices to minimize problems during your installation.
John Vellek
john.vellek
Hi @Anonymous,
I am following up with you to see if you were indeed able to get your product installed and running properly. Plesae update your status.
John Vellek
0 Me gusta
No aplicable
not yet...i gave up...i got autocad 2017. but need 2016 for advance steel,
n concret.....thankz doe
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I suggest that you consider going through the steps in my prior post. I need to say though if you have 2017 installed, you will not likely be able to reinstall 2016 without first removing 2017.
Advanced Steel is also available in a 2017 version should that be the easier route.
John Vellek
No aplicable
yea thank ive thought bout uninstall of 2017 but didnt wanta go though process agin....n i cant find advance steel or concret in the rite kind of download...only the brown installers which my pc wont install
0 Me gusta
