AutoCAD 2016 Failed Installation - Windows 10
Hello
Please help. I am having a problem installing AUTOCAD 2016 on windows 10.
I am a student and need to complete an assignment this is urgent.
FYI, I am not able to download AUTOCAD SP1 as recommendation as this is a patch  for already installed software (ithink) I have tried to download and it has failed.
I have received a serial number and licence key but the installation fails prior to being asked to provide this information.
No specific error code is given - the following message is displayed: Error Downloading. Please install Now from the Autodesk Website.
I following steps the following steps.
Go to my Autodesk account
All products & services
AutoCAD
Downloads
I have tried both install & download
Installation Scenario
1. Select  32/64 Install now
2. AutoCAD_2016_englsh_win_32_64bit_wi_en-us_Setup_wcbinstall.exe DOWNLOADS
3. Select Run
4. Autodesk Install Now
5. User Account Control - Do you want to allow this App (autodesk) to make changes to your PC? Select YES
6. Autodesk AUTOCAD Initilisation window in opened
7. Initilisation Starts - bar at bottom displays x or 172 MB downloading this progresses, THEN
8. Error Message is displayed: SetUp Initialisation Fails. Please install Now from the AutoDESK website
Note: A directory is created local but nothing installed - I cannot use uninstall to remove - these folders must be manually deleted.
Download Scenario
1. Select 64 download option
2. AutodeskdownloadManagersetup.exe Starts Downloading
3. Finishes downloading, Select RUN
4. User Account control (see 5 above) Yes
5. Autodesk install Manager starts
6. I get a communication failure from Autodesk Install Now
Note: The download manager can be uninstalled.
Machine details:
OS Name: Windows 10 pro
Model: HP Spectre Pro x360 G2
System Type: x64-based PC
Xhenyth
Hola Al parecer existe un inconveniente en el servicio de internet. Los motivos en realidad no estan del todo claros. Prueba descargando el software requerido desde el virtual agent http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk Download Links>Elige producto>Elige versiòn. Saludos Juan Sarmiento
Juan Ramón Sarmiento
BIM Modeler / CAD Expert
Proyectista en ingeniería estructural
Xhenyth
Hello Apparently there is a downside to the internet service. The reasons are actually not entirely clear. Try downloading the required software from the virtual agent http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk Download Links> Select Product> Select release. regards Juan Sarmiento
Hello Xhenyth, You are wonderful. After 4 hours of trying everything this morning I cam back to my machine to find your solution to my problem.
Thanks you so much.
I too got the same problem, then i did the directed way but still having problem to install.please help
I am also having issues downloading the student version of AutoCAD 2016 on my Windows 10 (home) laptop, but the virtual agent did not solve these issues.  My firewall is turned off and UAC has been disabled.  Using the Autodesk Virtual Agent I have tried both AutoCAD 2016 64-bit as well as AutoCAD Architecture 2016 64-bit.  About halfway through the download, it abruptly stops and says "Failed -- creativevirtual15.com".
