Anuncios
AutoCAD 2016 - DWG-PDF text issues
BerndSchulze
BerndSchulze
AutoCAD 2016 - DWG-PDF text issues Hi All Cannot find post dealing with same problem: Plotting to DWG-PDF In PDF settings - select all text to be converted to line:
0 Me gusta
Responder
968 Vistas
4 Respuestas
Respuestas (4)
Alfred.NESWADBA
I don't know if I'm correct how I understand your post. I do understand that you are searching for the settings to export text objects as geomtry or as text when creating a PDF with plot ur publish functionality.
This is an image which shows, starting from the plot dialog ... to the dialog with that setting (find attached image)
- alfred -
PS: this is a German forum, so we can either speak/write German or the english forum >>>there<<< is the better one for your future questions :cara_guiñando_un_ojo:
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Victoria.Studley
Hi @BerndSchulze,
Thank you for posting your question here in the community. Did @Alfred.NESWADBA's suggestion and screenshot help you find the "Convert all text to geometry" setting?
If you need more help, please post a Screencast or screenshot illustrating what you're trying to do, and what's going wrong, and I'll be happy to help you out.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
0 Me gusta
BerndSchulze
Hi VStudely Sorry for the delayed reply, was on holiday. attached herewith screen cast link 1: http://autode.sk/1kZFvSk attached herewith screen cast link 2: http://autode.sk/1PgKB4U text is not converted into lines, but remains visible, and editable. My client (MacUser) received the PDF drawings with text all over in different positions and scales. Hope this helps. Regards Bernd S
0 Me gusta
Alfred.NESWADBA
Have you installed SP1 for AutoCAD 2016?
Have you had a previous release of AutoCAD installed and migrated the settings when you first started 2016?
I'm not sure about your "convert text to geometry" settings as (a bad) decission was done to modify that setting on 2 different places now (with AutoCAD 2016).
You showed in the video that you changed the setting in the plot-dialog ==> button "PDF-Options". Can you try additionally in the plot dialog to
  • select the "DWG to PDF.pc3
  • right from that selection click on "Properties"
  • in this new dialog ==> seelct "Custom Properties" and when that is selected you get a button in the lower half "Custom Properties" ==> click it
  • And now see if here the "Convert all text to geometry" is checked
If nothing helped: Can you upload the drawing + your "DWG to PDF.pc3"?
- alfred -
Alfred NESWADBA
0 Me gusta
