Autocad 2016 Block has no editable attributes after copying
No aplicable
Hi All,
I use Autocad for Network documentation and I am making a new block for a new Cisco switch we are using.
When I take a copy of an existing block,explode it,  modify it by removing a few switchports and changing the model name, create a new block, and then "-WBLOCK" it... I get a new block but none of the editable attributes remain.
If I do this on Autocad 2015, works fine, but 2016 gives me this issue, can anyone help?
0 Me gusta
Responder
Soluciones aceptadas (1)
5.046 Vistas
6 Respuestas
Respuestas (6)
pendean
Community Legend
Community Legend
Post a sample of your block BEFORE to edited it and a copy of the edit afterwards, let's see for ourselves what may have been missed.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Why exploding anything, why not editing the block in the block-editor? Then you have all attributes as in the original blockdefintion.
>> create a new block
Are the attributes valid after creating the block (before using _WBLOCK?)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Before you wblock your new block definition out of your drawing, does the block you just created have attributes that can be edited?  I would like to see your drawing with the old and new blocks in it so I can help you to figure out what is not working properly.
John Vellek
0 Me gusta
No aplicable
Thank you guys, I ended up just using block editor rather than exploding it. never knew about the save block as function
Thanks a ton!
0 Me gusta
fahed1991
Community Visitor
Community Visitor
Autodesk AutoCAD 2021 - [KAAR-NPC-PW-CS-USW-ZN3-SPD-STR-06626-Rev.01.dwg].jpg
This is the quick solution
0 Me gusta
cadffm
Well - a quick solution (but for totally different problems).
Sebastian
0 Me gusta
