Anuncios
Autocad 2016 64bit windows 10 not responding
No aplicable
I have installed autocad 2015, then uninstalled it fully, and did a clean install of autocad 2016, then did a reinstall of autocad 2016 only, but nothing worked.
after clean installation of autocad again( the 2016 one), it worled flawlessly at first, but recently the same problem arised.
what happens is,
->The program loads properly as soon as I double click the Autocad 2016 icon.
->Then for a few microseconds when i hover my mouse, every button on the top(menu, minimize, maximize, close), get hilighted, this happens for approx. 2-3 secs
->Then all of a sudden i cannot click on the upper part..., but i can click on create, learn, start drawing.
-> create and learn are responsive and i can even open the vids.
->Start drawing, open, etc. buttons are useless( i can click but nothing happens).
Thats all i have been able to discover so far.
My config:-
Windows 10 64bit(autocad version 2016- 64bit- sp1),
6Gigs of ram,
Intel i7 5500U,
Intel HD 5500 graphics.
Thank You
0 Me gusta
Responder
3.771 Vistas
20 Respuestas
Respuestas (20)
rkmcswain
The body of your posts says "did a reinstall of autocad 2016 only" & the signature mentions SP1 for Acad2016.
Did you in fact install SP1 for AutoCAD 2016?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Window...
0 Me gusta
No aplicable
Yes
0 Me gusta
wispoxy
Please share any AutoCAD errors you encounter.
0 Me gusta
wispoxy
Only 6GB of ram for 64bit AutoCAD 2016 and Windows 10. Seems legit.
How do you even get Windows 10 to run with that little ram?
0 Me gusta
m_kingdon
Is hardware acceleration on? Try the command GRAPHICSCONFIG and turn it off.
Mike Kingdon
Civil 3D Zealot
No aplicable
Actually I am not able to do any thing else viewing the vids, in the learn tab
0 Me gusta
No aplicable
Bro, i tried to reset it almost 3 times, still the same thing
0 Me gusta
No aplicable
It ran on the first run, then the same...unresponsive thing
0 Me gusta
No aplicable
I get an error( but not always), after force closning it.
Attaching the snapshot link.
"https://drive.google.com/file/d/0Bz34P-ivJL7ETnBmaC1rcV9kMVE/view?usp=sharing"-Screenshot.
0 Me gusta
wispoxy
Please share that xml file. Review it first, make sure it doesn't include personal information or serial numbers.
0 Me gusta
No aplicable
I have a very little time to review it(i am busy working).
The File Contains:-
<?xml version="1.0" encoding="UTF-8"?>
<CERInfo ClientVersion="4">
<ProcessInfo
AvailPhysicalMem="C43C8000"
AvailPageFile="E0A62000"
AvailVirtualMem="7FFF2CDD5000"
LastWin32Error="1816"
ErrNo="183"
<UserInfo UserCanBeContacted="yes" SerialNum="xxx-xxxxxxxx">
<UserName value =""/>
<UserPhone value=""/>
<UserEmail value="V.Mr.Gamer@gmail.com"/>
<UserSubscription macID="{8D6E8776-BDF0-4DF9-9115-7F664C4A10D7}" userId=""/>
<ErrorDescription id="2" CrashDate="19-11-2015" CrashID="{38969785-016D-49B1-8D50-9062BD31282C}" AllowRT="1"></ErrorDescription>
<Metrics CalendarUptime="3335217619" RequiredSend="0" WaitDur="10000" /></UserInfo>
<upipackage><upivalue version="1.0" type="product" requestingapp="true"><level name="productline" id="ACD"><level name="release" id="2016"><level name="master" id="{5783F2D7-F001-0409-2102-0060B0CE6BBA}"><level name="build" id="20.1.107.0.0"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="Autodesk_Material_Library"><level name="release" id="2015"><level name="master" id="{8DD6453A-32B6-4881-9026-A1CBFAE661A2}"><level name="build" id="5.2.9.100"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="Material_Library_Base_Resolution_Image"><level name="release" id="2015"><level name="master" id="{C8B03658-A1A9-4D93-9A1F-8BF7B889A1C1}"><level name="build" id="5.2.9.100"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="ADAPPMAN"><level name="release" id="2015"><level name="master" id="ADAPPMAN_WIN32"><level name="build" id="5.0.142.5"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="PLC0000013"><level name="release" id="2016"><level name="master" id="{8DD6453A-32B6-4881-9026-A1CBFAE661A2}"><level name="build" id="6.3.0.15"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="PLC0000021"><level name="release" id="2016"><level name="master" id="{4C7BAB99-E6C8-406E-B3D0-04B414C2CB53}"><level name="build" id="6.3.0.15"/></level></level></level></upivalue>
<upivalue version="1" type="product"><level name="productline" id="RECAP"><level name="release" id="2015"><level name="master" id="{31ABA3F2-0000-1033-0102-111D43815377}"><level name="build" id="1.3.1.39"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="PLC0000002"><level name="release" id="2015"><level name="master" id="ACD_ENU_64"><level name="build" id="3.32.3004"/></level></level></level></upivalue>
<upivalue version="1" type="product"><level name="productline" id="PLC0000026"><level name="release" id="2016"><level name="master" id="{F6FD1651-0000-1033-0102-387BAF9B3B0A}"><level name="build" id="1.5.0.33"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="PLC0000002"><level name="release" id="2016"><level name="master" id="ACD_ENU_64"><level name="build" id="4.37.2870"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="ADSKContentExplorer"><level name="release" id="2013"><level name="master" id="2013"><level name="build" id="3.0.0"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="ACD"><level name="release" id="2016"><level name="master" id="{5783F2D7-F001-0000-0102-0060B0CE6BBA}"><level name="build" id="20.1.107.0.0"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="ACD"><level name="release" id="2016"><level name="master" id="{5783F2D7-F001-0409-1102-0060B0CE6BBA}"><level name="build" id="20.1.49.0.0"/></level></level></level></upivalue>
<upivalue version="1.0" type="product"><level name="productline" id="ARCHDESK"><level name="release" id="2016"><level name="master" id="{5783F2D7-F004-0000-5102-0060B0CE6BBA}"><level name="build" id="7.8.41.0"/></level></level></level></upivalue>
</upipackage><OSInfo MajorVersion = "6" MinorVersion = "2" BuildNumber = "9200" PlatformId = "2" CSDVersion = "" ServicePackMajor = "0" ServicePackMinor = "0" SuiteFlags = "300" KernelMajorVersion = "10" KernelMinorVersion = "0" KernelBuildNum = "10240" KernelReleaseNum = "16384"/>
<LocaleInfo> <LocalUserDefault IDefaultAnsiCodepage="1252" IDefaultCodepage="437" IDefaultLanguage="4009" IDefaultCountry="91" ILanguage="4009" ICountry="91" />
<LocalSystemDefault IDefaultAnsiCodepage="1252" IDefaultCodepage="437" IDefaultLanguage="4009" IDefaultCountry="91" ILanguage="4009" ICountry="91" />
</LocaleInfo>
<WininetInfo WininetMajorVersion = "11" WininetMinorVersion = "00" WininetBuildNum = "10240" WininetReleaseNum = "16384"/>
<MC3Info sessionId="{72c77ba2-f1bc-43b7-ab48-b59ae4826cfe}" userId="2FD8CC2E514713BEB2A7EB284EEE63C7539707E939AD89DEBC140DC92746DB43_8CB49E21F9A2F60D82ADDBD76590033B5241832A85AD2F5E16FA1CFEC13BB969_18742513EB1212C59475CC44B24DEE2E166D733A17DCD3A08E1A9CBF1C02D910" />
<ProductInformation name ="AutoCAD" build_version="M.107.0.0(x64)" registry_version="20.1" install_id_string="ACAD-F001:409" registry_localeID="1033" uptime="515000000" session_start_count="2" session_clean_close_count="0" current_session_length="154"><GsConfig version="1.0" certification="Dx11"><Card name="Intel(R) HD Graphics 5500" driver="10.18.15.4240"/><VirtualDevice><Current>"Dx11"</Current></VirtualDevice><Settings><HWFeatureLevel>"50"</HWFeatureLevel><SWFeatureLevel>"50"</SWFeatureLevel><HWAccelerationAvailable>"1"</HWAccelerationAvailable><HWAccelerationEnabled>"1"</HWAccelerationEnabled><HWAccelerationRecommended>"0"</HWAccelerationRecommended></Settings><Effects><Effect name="ACAD_LineSmoothing" enabled="1" available="1" recommended="1"/><Effect name="ACAD_PerPixelLighting" enabled="1" available="1" recommended="1"/><Effect name="ACAD_AdvancedMaterial" enabled="1" available="1" recommended="1"/><Effect name="ACAD_FullShadows" enabled="1" available="1" recommended="1"/><Effect name="ACAD_TextureCompression" enabled="0" available="1" recommended="1"/><Effect name="ACAD_HQGeom" enabled="1" available="1" recommended="1"/><Effect name="ACAD_GlowHighlighting" enabled="1" available="1" recommended="1"/><Effect name="ACAD_Dx11" enabled="1" available="1" recommended="1"/></Effects><GDI><GDIOBJECTS>244</GDIOBJECTS><USEROBJECTS>156</USEROBJECTS><GDIOBJECTSPEAK>274</GDIOBJECTSPEAK><USEROBJECTSPEAK>372</USEROBJECTSPEAK></GDI></GsConfig></ProductInformation><AdLmInformation init="0" command="0" conditions="" /><AppCDATA><![CDATA[]]></AppCDATA>
<OpenGLInfo Vendor = "Intel" Renderer = "Intel(R) HD Graphics 5500" Version = "4.3.0 - Build 10.18.15.4240" />
<GraphicsDriverInfo Driver = "acaddm12.hdi" />
<GraphicsInfo InfoType="D3D9Config"><![CDATA[
Driver: igdumdim64.dll
DriverVersion: 10.18.15.4240
Description: Intel(R) HD Graphics 5500
DeviceName: \\.\DISPLAY1
VendorId: 32902
DeviceId: 5654
SubSysId: 112070696
Revision: 9
WHQLLevel: 0
DeviceType: 1
AdapterOrdinal: 0
Caps: 131072
Caps2: 3758227456
Caps3: 800
Presentation: 2147483663
Cursor: 1
Dev: 1683024
PrimitiveMisc: 3132658
Raster: 259219857
ZCmp: 255
SrcBlend: 16383
DestBlend: 10239
AlphaCmp: 255
Shade: 541192
Texture: 2223173
TextureFilter: 117638912
CubeTextureFilter: 117638912
VolumeTextureFilter: 117638912
TextureAddress: 63
VolumeTextureAddress: 63
Line: 31
MaxTextureWidth: 8192
MaxTextureHeight: 8192
MaxVolumeExtent: 2048
MaxTextureRepeat: 8192
MaxTextureAspectRatio: 8192
MaxAnisotropy: 16
MaxVertexW: 1e+010
GuardBandLeft: -16384
GuardBandTop: -16384
GuardBandRight: 16384
GuardBandBottom: 16384
ExtentsAdjust: 0
Stencil: 511
FVF: 1572872
TextureOp: 67108863
MaxTextureBlendStages: 8
MaxSimultaneousTextures: 8
VertexProcessing: 379
MaxActiveLights: 8
MaxUserClipPlanes: 6
MaxVertexBlendMatrices: 4
MaxVertexBlendMatrixIndex: 0
MaxPointSize: 256
MaxPrimitiveCount: 8388607
MaxVertexIndex: 16777215
MaxStreams: 16
MaxStreamStride: 255
VertexShaderVersion: 4294836992
MaxVertexShaderConst: 256
PixelShaderVersion: 4294902528
PixelShader1xMaxValue: 3.40282e+038
Dev2: 81
MasterAdapterOrdinal: 0
AdapterOrdinalInGroup: 0
NumberOfAdaptersInGroup: 1
DeclTypes: 895
NumSimultaneousRTs: 4
StretchRectFilter: 50332416
VertexTextureFilter: 50529024
MaxVShaderInstructionsExecuted: 4294967295
MaxPShaderInstructionsExecuted: 4294967295
MaxVertexShader30InstructionSlots: 32768
MaxPixelShader30InstructionSlots: 32768
]]></GraphicsInfo>
<DxDiagInfo><SystemInformation><OperatingSystem><![CDATA[64-bit Windows 10 Home 64-bit (6.2, Build 9200) (10240.th1_st1.151104-1714)]]></OperatingSystem><Language><![CDATA[English (Regional Setting: English)]]></Language><SystemManufacturer><![CDATA[Dell Inc.]]></SystemManufacturer><SystemModel><![CDATA[Inspiron 5558]]></SystemModel><BIOS><![CDATA[A04]]></BIOS><Processor><![CDATA[Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz (4 CPUs), ~2.4GHz]]></Processor><SystemMemory><![CDATA[6144MB RAM]]></SystemMemory><PageFile><![CDATA[3043MB used, 3971MB available]]></PageFile><FullDirectXVersion><![CDATA[DirectX 12]]></FullDirectXVersion><DxDiagVersion><![CDATA[6.02.10240.16384]]></DxDiagVersion></SystemInformation><GraphicsDeviceInfo><DirectXVersion><![CDATA[12.0]]></DirectXVersion><DDIVersion><![CDATA[12]]></DDIVersion><DDIVersionNumber><![CDATA[c]]></DDIVersionNumber><DxDiagWHQLLevel><![CDATA[0]]></DxDiagWHQLLevel><DriverSignedValid><![CDATA[True]]></DriverSignedValid><DriverSigned><![CDATA[True]]></DriverSigned><Manufacturer><![CDATA[Intel Corporation]]></Manufacturer><ChipType><![CDATA[Intel(R) HD Graphics Family]]></ChipType><DACType><![CDATA[Internal]]></DACType><GraphicsHWMemory><![CDATA[3155 MB]]></GraphicsHWMemory><DisplayMode><![CDATA[1366 x 768 (32 bit) (60Hz)]]></DisplayMode><VendorID><![CDATA[0x8086]]></VendorID><DeviceID><![CDATA[0x1616]]></DeviceID><SubSystemID><![CDATA[0x06AE1028]]></SubSystemID><RevisionID><![CDATA[0x0009]]></RevisionID><GraphicsDriverFile><![CDATA[igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32]]></GraphicsDriverFile><DriverFileVersion><![CDATA[10.18.0015.4240]]></DriverFileVersion><DriverDate><![CDATA[7/1/2015 00:56:48]]></DriverDate><WHQLLevel><![CDATA[1]]></WHQLLevel></GraphicsDeviceInfo></DxDiagInfo><VideoDriverInfo><ATIPackagingVersion><![CDATA[No value found]]></ATIPackagingVersion></VideoDriverInfo>
</CERInfo>
0 Me gusta
rkmcswain
0 Me gusta
No aplicable
No luck man, the same again
0 Me gusta
wispoxy
Still evaluating your log report.
0 Me gusta
wispoxy
Posting my evaluation report, get ready for excitement.
0 Me gusta
wispoxy
Executions Failed = 1,253
Backup Accepted = No
1816 (0x718)
Registry track failed. Registry track unaccepted.
.NET Repeat Log Image
      [System.Security.SecurityCritical]  // auto-generated_required
      [ResourceExposure(ResourceScope.None)]
      [MethodImplAttribute(MethodImplOptions.InternalCall)]
      [ReliabilityContract(Consistency.WillNotCorruptState, Cer.Success)]
      public static extern int GetLastWin32Error();
Invalid hash algorithm registered. It seems you have another program interfering with the registry.
Or an AutoCAD version mix. Are you using Norton Symatic?
0 Me gusta
No aplicable
I don't have Norton, instead is use MacAfee
0 Me gusta
