AutoCAD Forum
Welcome to Autodesk’s AutoCAD Forums. Share your knowledge, ask questions, and explore popular AutoCAD topics.
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
AutoCAD Forum
Post 1 of 17
Accepted Solution
Autocad 2015 Windows 10 Preview fatal Error
19998 Views, 16 Replies
10-04-2014 09:52 AM
hello guys, i installed the AutoCAD 2015 on my PC and i got this error: FATAL ERROR: Unhandled e0434352h Exception at eeb0b518h, tried to reinstall 4 times, and search all over the web but nothing makes the program run, could someone help me?Sem título.pngr
error2
Proprieties
Heck, AutoCAD2015 is "barely" compatible with Win7 and Win8.  I'd say you're pretty much on your own trying to run it on an unrelease and unsupported OS.
You need to fix the problem in Win7/8, not go hoping some incomplete unsupported preview OS is going to be the solution.
That fatal error is very generic and often system related: we've ruled out the OS, so what else do we need to know? AutoCAD variant, are you installting from the net or have you actually downloaded the complete+1.5Gig file and starting from there? Is there an error log in WIndows? What other Autodesk applications are installed?
Also, see if this article helps.
Hello All,
To provide an update on this topic and thread.
The English language versions of AutoCAD 2015 and AutoCAD-based verticals should be installable if you have received the Windows 10 update, KB3081448 or later.
Other AutoCAD language versions and language packs can be installed if Windows 10 update, KB3105210, is applied prior to installation.
DWG TrueView 2015 can be installed if Windows 10 update, KB3105210, is applied prior to installation.
If you are having an issue with Microsft C++ and .NET please read through the AKN article and suggestions made in this thread by your fellow community members.
Any and all feedback is welcomed! Thank you for your participation. Smiley Happy
Post 2 of 17
Re: Autocad 2015 Windows 10 Preview fatal Error
10-04-2014 04:37 PM in reply to: gabriel_hmv
Post 3 of 17
10-04-2014 11:24 PM in reply to: nestly2
yeah, i know that, but i tried to install on Windows 8 and Windows 7 and i get the same error :/
Post 4 of 17
10-06-2014 06:47 AM in reply to: gabriel_hmv
Dean Saadallah
AutoCAD, LT and Architecture User
Blog | Google+ | PINS
Facebook | Twitter | LinkedIn
Post 5 of 17
10-06-2014 09:05 AM in reply to: pendean
Instaled used the Instaler get from Autodesk site. No error log on windows until now, i tried Autocad MEP and get the same error
Post 6 of 17
10-06-2014 09:16 AM in reply to: gabriel_hmv
You may need to remove all instances of .NET, remove all Autodesk software per Autodesk's guidelines, restart Windows and reinstall 2015.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Ensure you download the +1.5Gig installer file from AUtodesk before you try installing it
Dean Saadallah
Post 7 of 17
10-06-2014 09:28 AM in reply to: pendean
gonna try this now, thankyou for everything!!
Post 8 of 17
06-06-2015 04:37 AM in reply to: gabriel_hmv
Post 9 of 17
06-11-2015 10:40 AM in reply to: pendean
1+
No issues with Windows 10 as a clean install; just be sure to create a SystemImage of your Win7/8 install first.
Cheers
http://www.theswamp.org/index.php?topic=49097.15
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
AutoCAD®, and Civil 3D® Certified Professional ~ Autodesk® Authorized Developer
Post 10 of 17
will autocad and revit 2015 work with WINDOWS 10
08-06-2015 09:29 AM in reply to: gabriel_hmv
 i would like to know if someone has allready downloaded WINDOWS 10 and try to run autocad or revit 2015
have you had any problems? or does it work normally?
Post 11 of 17
Re: will autocad and revit 2015 work with WINDOWS 10
08-06-2015 09:32 AM in reply to: m-g-zuhu
yea try searching this forum or the internet
Post 12 of 17
08-06-2015 09:45 AM in reply to: m-g-zuhu
Dean Saadallah
Post 13 of 17
08-07-2015 08:21 AM in reply to: m-g-zuhu
me. fatal error always occur upon launching autocad. :( if anyone could help your suggestions would be very much appreciated. :(
Post 14 of 17
08-07-2015 08:26 AM in reply to: akosirenz14
Post 15 of 17
08-07-2015 09:00 AM in reply to: Patchy
I successfully installed autocad 2014 on my windows 10 but when i try to open it, "FATAL ERROR" always occur. how can i fix this?
Post 16 of 17
08-07-2015 11:48 AM in reply to: akosirenz14
Post 17 of 17
03-16-2016 02:40 PM in reply to: gabriel_hmv
Hello All,
Sarah Emmsley
Technical Support Specialist
Post to the Community
New Post
