Autocad 2015 Problem Saving Command
Having trouble with the ‘text edit’ command.
Every now and again I type in TE for the command it says unknown command, After one r two attempts it then recognises the command.
I also use to be able to double click to edit single line text but now I cant and I have to use the TE command. Don’t know why this has been removed
Currently using Win7 64bit
regisrohde
type command options.
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
pendean
Community Legend
Community Legend
Turn off some of the 'helpful' typing features in 2015 and that should take care of why you cannot type the shortcuts.
I can type in shortcuts, but sometimes to works a few times then doesn't recognize?
Also how do I remove 'helpful' typing features?
nestly2
INPUTSEARCHOPTIONS  <-- Link
I would start by adjusting AutoComplete settings and delay time
