AutoCAD 2015 keeps changing to paper space
Message 1 of 13
I recently upgraded from 2012 to 2015. For some reason, my cad automatically switches from working in the model space to the paper space even when I am using a command. Is anyone able to help with this or could there be some sort of bug on the server?
Replies (12)
Message 2 of 13
nrz13
Here are some thoughts:
http://forums.autodesk.com/t5/autocad-2013-2014-2015/automatically-switch-to-paper-space-when-zoom-o...
http://forums.autodesk.com/t5/autocad-2013-2014-2015/paper-model-space/m-p/5099770/highlight/true#M5...
See if any of the suggestions/tips listed in those threads help you.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 3 of 13
kcobabe
Are you doing a lot of panning and zooming in a locked viewport?  If you do this for an extended time, the autosave often will throw you back into paper.  Not exactly sure why it does this, but it's usually what happens to me.  Very irritating, but I'm sure there's a reason.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 4 of 13
Yeah I am doing a lot panning and zooming. Only had 2015 for a month or so. Tempted to go back to 2012. I've turned auto save off for the time to see if that makes a difference.
Message 5 of 13
kcobabe
Hope you don't crash 😉  I would get into the habit of qsaving if you plan on doing that.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 6 of 13
This happens to me a lot. I create a new drawing, copy and paste everything into it, then save that over the buggy one. This seems to fix it. Good luck!
Message 7 of 13
zenkai
Was there any fix to this? I just installed 2016 and it's doing it to me, it's driving me crazy.  I will be zoomed in on my drawing dimensioning, next thing I know I amin paperspace and my dimension are half in paper and half in model!
Message 8 of 13
pendean
Community Legend
Community Legend
The post above yours offered a fix.
Message 9 of 13
zenkai
Didn't work and not a good option anway, there is 0 issues with 2015 which I am back to running.
Message 10 of 13
Found a better fix for this-
Mouse over the tab of the drawing you're having trouble with, a menu should appear with several layouts, click the model space. This fixes the problem for me every time.
I hope this works for you!
Message 11 of 13
zenkai
How does clicking model tab fix it? It doesn't.  I draw in model space, but when I dimension I use viewports in paper space because I use anotation scales.  That's the mot effeciant way to draw, I am not using release 12 where I dimension in model space.
To everyone else I found not a fix but something to lesson the annoyance.  I am on windows 10, it seems its something to do with that, I was on 7, because it does it with AutoCAD 14 and 15 too even though I didn't have an issue before
By chaninging the compatability mode on acad.exe to windows 7 the problem happens less often but it does till happen
Message 12 of 13
how do you change the compatability of acad.exe to windows 7?
Message 13 of 13
zenkai
Locate acad.exe.  Right Click, go to properties, in properties go to compatibility tab.  Check the Box "Run in compatibility mode" Select Windows 7 and click ok or apply.
