Autocad 2014 Mouse Input Issues
Hey All,
I'm running Autocad 2014 and am having issues inputing commands with my mouse.  I am using a Logitech MX Master and have been drafting and designing with it for the past 2 months with no issues.  Whenever I use my programmed buttons on the mouse, the letter (P,R,M,C) pops up in the command bar, but it does not access the shortcut to my corresponding commands.  If I hit my PolyLine command shortcut (P) and hit the space bar, for instance, I get [Command: p Unknown command "P". Press F1 for help.]   When I use my keyboard to type the same shortcuts for the commands (P,R,M,C) it works with no issue.  I am drawing in model space.  What do you guys and gals think is going on here?  Thanks for any advice!
rkmcswain
You might also ask in the "Pointing Devices and Display" forum...?
http://forums.autodesk.com/t5/pointing-devices-and-displays/bd-p/17
R.K. McSwain     | CADpanacea | on twitter
Thanks for the heads up!
