Autocad 2014 makes shadow while change tollbars position
mehedi.apu74940954ZUG
Hi, There's a problem I facing some days. While I changed toolbars position in Auto Cad 2007/2014/2018( I use those versions) it makes a shadow/blur of previous position of this toolbar which I changing position. Please give me a solution about this. Thanks in Advance. :cara_con_una_leve_sonrisa:
0 Me gusta
Responder
Soluciones aceptadas (2)
348 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Solución aceptada
That is known when the latest Windows 10 update is installed (and not just AutoCAD, happens in other applications too using a specific API function).
BTW: AutoCAD 2014 is not supported in Windows 10 :cara_guiñando_un_ojo:
What is the problem? How often do you move toolbars?
I would recommend that you arrange them as they should be and lock the UI.
Then you don't have any issue that could be solved.
(I know a lot more issues which are more important as they occure daily)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Solución aceptada
Hi Alfred ,
0 Me gusta
