AutoCAD 2013 wont install on Windows 10
No aplicable
I have 2013 versMion and i cant install it on Windows 10. It says that Microsoft IIS is not installed. Then it gives me two options to automatically install it or stop and install manually.
I wouldnt mind but the automatical install option can not be selected.
Please help me, as I really need the program.
Kindest regards,
Daina Bluzmane
0 Me gusta
Responder
Soluciones aceptadas (1)
3.264 Vistas
6 Respuestas
Respuestas (6)
No aplicable
Your best bet is to roll back to a previous version of Windows.
0 Me gusta
No aplicable
Kindest regards,
Daina Bluzmane
you probably should have done your research first
this is all Autodesk has announced for Windows 10
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Windows-10-support-for-Autodesk-products.html
other threads on this subject: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=windows+10
roll back to the previous OS when it was working
http://www.cnet.com/how-to/windows-10-how-to-roll-back/
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
Big boy leap without the big boy research, huh!
Win10 installs are for experienced PC power users at the moment, is that you? If yes, Win10's compatibility mode may be all you need to do, look up how to do that in Win10's HELP or at Microsoft's. You need to be a full admin in your Win10 log-in, and just so you know I suspect Autodesk is not going to support the 'home' versions of Win10.
Or whip out a credit card and find a company called Longbow Software ans see if they will sell you a fix.
If you want free and easy fix, you'll need to wait on Autodesk for a solution in the next few weeks or months or never, no one knows for sure yet.
0 Me gusta
No aplicable
Thanks for help.
I figured out what was wrong and have it working now perfectly on my Windows 10. And I also upgraded to AutoCAD 2015.
0 Me gusta
barrett
Observer
Observer
How did you resolve the problem?
0 Me gusta
No aplicable
Maybe it is the same problem when installing AIMS2015 under Windows 10. I described and solved it here: http://forums.autodesk.com/t5/infrastructure-map-server/how-to-fix-installation-of-aims-2015-under-w...
0 Me gusta
