AutoCAD 2012 64bit the ribbon menu all white?
As you can see here. I used Acad 2012 64bit on Win10 64 bit.
In the red, all the button go white.
In the blue, the file name go white.
How can I fix it?
Pls help.
Thanks.
Alfred.NESWADBA
AutoCAD 2012 was introduced long time before Windows 10 came to live, so it is not a suggested environment (>>>click for system requirements AutoCAD 2012<<<).
You might try to disable hardware acceleration (command _3DCONFIG ==> manual tune)
In Windows 7 there were similar cases which then need to remove AERO, but I don't think that changing any Windows display theme settings would do the same now.
For such an old AutoCAD I would use a virtual system (like Oracle VirtualBox or VmWare Player) and install Windows 7 in that system.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
If the free tips on running old software on unsupported Windows versions here do not work, these folks also sell you a fix to help make it work https://www.longbowsoftware.com
