AutoCAD Forum
Autocad 2011
6 REPLIES 6
1731 Views, 6 Replies
Autocad 2011
I lost my Autocad 11 CD and need to install again coz my hard disk got busted. i Can't find any link on Autodesk web side for Acad 11. They have only from Acad 12 and up.
can someone help me please. I need it rightaway.
6 REPLIES 6
philip.s
Here you go and welcome to the community @Anonymous!
AutoCAD 2011 32BIT - LINK
AutoCAD 2011 64BIT - LINK
For anyone else who might need an older link that is not available on the Autodesk Virtual Agent, please contact our Customer Support Team.
in reply to: philip.s
Thanks for the link, but i forgot mention, i need 64bit not 32bit. Can you please send me 64bit link. Thanks
*edited to remove signature block from reply by email
philip.s
It was actually already there / I had just copied the text over from the 32bit line. Just renamed 🙂
I also lost my Autocad 2011 LT CD but i have the key
I found your link that can work for me but its not in french.
Is it possible to have it in my own language ?
Thank you !
J.
nestly2
Welcome to the Autodesk Forums.
A link to AutoCAD 2011 LT 64bit French Language can be found here  (note, links to older versions that are no longer supported usually have an expiration date)
in reply to: nestly2
I will donwload it right now. i tried the search engine with no luck.
Thank your for your time.
j.
Forma Design Contest
