Autocad 2010
Autocad 2010
No aplicable
Does basic(?) Autocad 2010 include Autocad 2010 Electrical or is Autocad 2010 Electrical a stand-alone download?  Or, can the Electrical be integrated with the basic(?) Autocad 2010?  Much Thanks, CNM.
0 Me gusta
Responder
Soluciones aceptadas (2)
7.201 Vistas
8 Respuestas
Respuestas (8)
wispoxy
No, AutoCAD Electrical is a stand-alone.
Basic AutoCAD does not include AutoCAD Electrical. AutoCAD Electrical has more than AutoCAD, It's basically AutoCAD with Electrical Tools. Notice the price difference in the following link: http://www.autodesk.com/products/autocad-electrical/compare-products
0 Me gusta
No aplicable
Thanks for quick response! Q. Will AutoCAD 2010 Electrical allow for
physical layout in a panel along with physical dimensioning? Thanks, CNM.
pendean
Community Legend
Community Legend
Solución aceptada
AutoCAD Electrical forum is way over here, they'll answer all your questions about it better http://forums.autodesk.com/t5/autocad-electrical/ct-p/2035
wispoxy
Solución aceptada
Yes.
No aplicable
Last question - are there any major differences between AutoCAD Electrical
2010 and AutoCAD Electrical 2015 or are they basically the same? Much
Thanks, CNM
wispoxy
Here is a list for Autocad 2011-2015, for Electrical Specifically I do not know. This list still applies to AutoCAD Electrical 2015 because remember what I said earlier, it's AutoCAD with electrical tools. Check out my full list that I just posted >HERE<
2011
  • Grid - lines in 2D
  • Ribbon updates, added 3D Basic WS
  • Grip added to polyline
  • Selection cycling enhancement  -  SC toggle at bottom of screen
  • Multifunctional grips
  • SelectSimilar command added, HideObjects, Unhide,
  • AddSelected command added
  • HideObjects command added
  • IsolateObjects, UnisolateObjects
  • 3D object snaps
2012
  • Autocomplete command
  • VpControl viewport controls - navigation, views and visual styles on screen
  • Ribbon sizing - three minimized settings
  • mtext background remembers last used fill color and offset
  • grip with lengthen option
  • grips are multi-functional for more objects - arcs, assoc arrays, dims, elliptical arcs, lines, mleaders, 3d faces edges vertices
  • Associative Arrays, grips editing
  • Blend - connects two objects using a spline
  • Extend works with Splines, Fillet works with Splines
  • Support for multiple paths for PMP, PC3, CTB, STB files
  • Snap can be set to work only while in a command, SnapMode sysvar
  • Drawing Views - 2D drawing views from 3D model and 1st or 3rd angle projection Base View
  • 3D editing - ChamferEdge and FilletEdge added Loop option
  • 3D editing - OffsetEdge
  • MeshCap has options added
  • Point Clouds enhanced
2013
  • drawing views additions, create details and sections
  • Properties - shows realtime previews for colors, lineweights, lintypes, transparency, layers
  • Array - displays contextual tab, uses default values to show instant previews
  • Offset has preview before picking
  • Polylines - reversed plines with varying widths handled with new sysvar PlineReverseWidths
2014
  • command line - spell checking, synonyms, block names, layer names, hatch name, visual styles, dim style
  • autocorrect - after three misspellings the word is added
  • type at command line to change layer, text style, dim style, visual style
  • type at command line with hatch name to start hatch command
  • type at the command line with a block name and the insert command will start
  • mid string search at command line
  • Drawing Tabs - tabs displayed for each drawing
  • Chamfer command closes polylines
  • Filleting polylines will close polylines
  • Layers - merge selected layers in layer manager (LAYERDLGMODE must equal 1)
  • Xref layer names are not shown in the properties palette
  • Xrefs can be selected in quantities and the path or xref type changed in-mass
2015
  • User interaction - Start, Help Find tool, Dark theme, Ribbon gallery, Improved graphics, Lasso selection, Command preview, Resizable modelspace viewports
  • Design - Point cloud manager, Cropping, and object snaps, 3D Orbit Target
  • Documentation - Autobullets and numbering, Mtext match properties, Mtext superscript and sibscript tools, Caps lock detection
  • Connectivity - Design feed with local drawing storage, Autodesk translation framework
  • Customization - BIM 360 add-in, Autodesk Application Manager, Performance reporting
0 Me gusta
JDMather
Do you already have these products (can't generally purchase or license old releases)?
For physical 3D layouts (not schematics) you might also look at Autodesk Inventor Professional - Routed Systems.
0 Me gusta
No aplicable
autocad 2010 version
0 Me gusta
