AutoCAD 2010 doesn't recognize 3DOsnap commands
morganism3
morganism3
My AutoCAD 2010 at work is not recognizing any keyboard commands related to 3D object snaps. Also if I hit F4, instead of giving me 3DOsnap, it says, "CALibrate the TABLET before turning it ON  <Tablet off>". (I'm on a PC, have no idea what this command means). I tried OPTIONS and couldn't see anything relevant there.
john.vellek
HI @morganism3,
AutoCAD 2010 is rather old and I don't have a copy installed. Try though to go back into options and check to see what is selected for your Current Pointing Device. It sounds like you might have Wintab selected.  Change that to Current System Pointing Device and perhaps that will correct this behavior.
John Vellek
john.vellek
Hi @morganism3,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
